Unsure how to connect up external connections need to see illustration for these connections as i do not have any info'
  • 378 Answers
Tape decks has a line out and line in RCA jack at the rear this is for the amplifier connection. line out should be connect to amplifier line in jack. Tape deck has also RCA jack input for Radio or Tuner, Phono, VCR, or CD, and Aux. You can input the audio out R&L to the selected input above.
Posted on Jun 21, 2009
Why does cd rom not conned to my macbook?
I'm not sure about this, because I have an internal CD/DVD in my macbook. But this can be a driver issue. Do you have an Apple CD drive, or an universal USB CD drive? The last one could be very tricky, because the computer needs special drivers, so it can recognise the external drive.
Jun 06, 2014 | Apple MacBook Pro Laptop Computer with...
No Audio on external device via VGA
Dear Paul,
VGA cables have no provision to carry audio signal - they only carry video signals.
In general, external monitors that also have speakers have RCA-type or miniplug-type audio inputs. In this case, you will need to use another audio cable to connect the phones output of your laptop to the input of your monitor, using a suitable cable.
If you provide us the model number of your laptop, as well as the one for your external monitor, we could try to find the info regarding the kind of audio cable needed to connect both.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
Feb 01, 2014 | Fujitsu LifeBook Computers & Internet
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Astone 1 TB ex hardrive no longer recognised by computer
You need the device drivers for Win-7 for that hard drive to work. You can try to locate one on their website, but I couldn't find any....
http://www.astone.com.au/index.php?downloads=yes
Jan 07, 2010 | Computers & Internet
Dont have the intalation disc
Here is the info from Sony's Website.
Drivers for External Optical Models Operating System: Windows Date: 04/18/2008 Do you need a Driver? (External models)
All Sony Optical external units are plug & play with Windows, no drivers are required for detection.
If you are having issues getting your external drive detected in Windows, please try the following:
The drive needs to be connected directly to USB 2.0 or I-link port (depending on model type) on your computer. Please note that the drive is not supported if connected to a dock or a hub.
Also please check the following if you are have trouble detecting:
  • The drive needs to be the only external device connected to the system. Please ensure there are no other USB devices connected.
  • Try a different USB port on your computer.
  • Try a different USB cable
  • Try the drive on a second computer system if possible.
  • Ensure you have the latest BIOS and Motherboard updates from your PC manufacturer.
  • Ensure you have the latest Windows updates from Microsoft.
I hope that this helps in some way. Please let me know if you need more help after these steps and I will try looking eleswhere. asnowman
Nov 07, 2009 | Sony DRX-820U Burner
I need to run an HDD2159 external of its computer.
You cannot just connect the hard drive using a SATA to USB cable and connect it to the computer and expect to download data from this hard drive.
You need to connect the hard drive to an USB hard drive adapter which is then connected to a computer's USB port?
Leave the hard drive set as the master drive.
Oct 02, 2009 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Hp officejet v40
Manuals for the V40 are available for download here. The information you are looking for is in the setup poster, part 6.
The wall connection connects to the rightmost connection (looking from the rear). If you have a phone it would plug into the leftmost jack. It may be necessary to remove a plug from the leftmost jack if you use an external phone.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 03, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
100 people viewed this question
 Grubhead
Grubhead
