Question about Apple iPhone 3G
How to recover Restriction Passcode - iPhone 3g 2.2.1 jailbroken
I just purchased a used iPhone 3g jailbroken having firmware 2.2.1. The problem is that the Restriction Passcode is enabled on it which would not allow me to add any new application. How do I recover the passcode? I bought the phone from the shop and the guy there doesn't know the passcode either. Please Help
  • Anonymous Mar 16, 2014
    I don't want to have to enter my passcode every time I use my new iPhone 5s, but cannot see the same section under 'general' where it was on my 4s phone. Can someone pease advise how I do this please?
Ok! I figured it out... What I did was, I simply restored the phone with the backup taken from another phone with the same name and now my Restriction Code is blank (as it was blank in the other phone)
Posted on Jun 22, 2009
Can I use multitasking on a jailbroken iPhone 3G?
Welcome to FixYa. Short answer: yes, you can enable some sort of multitasking on a jailbroken iPhone devices, even on an iPhone 3G - however, your hardware won't be able to handle the severe increase in memory usage, making your phone highly unstable. I would advise against trying to use this, your phone simply can't handle it.
Mar 13, 2011 | Apple iPhone 3G
I have the iPhone 3G with 4.2.1 Firmware update. In trying to Jailbreak with Limera1n it does not work with 4.2.1 but does with 4.1 or 4.0. Can I revert back to 4.1 or 4.0?
Use greenpois0n. its the new and better application for jailbreaking. works wonders. i have my iphone 4 jailbroken with it and it didnt give me a problem.
Good Luck!
Jan 30, 2011 | Apple iPhone Smartphone
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
To unlock iphone 3g
You need your device to be on a 3.1.2 firmware & jailbroken
Jun 12, 2010 | Apple iPhone (16 GB) Smartphone
I have forgotten my passcode on my ipod, how can i remove it ?
follow this instruction.
but you must understand that if you do that all contents of your iPhone will be removed, including the passcode and including the jailbreak if your iPhone is jailbroken. the software will be as good as brand new.
good luck.
for more iPhone / iPod touch tips, click here.
Feb 15, 2010 | Apple iPhone 3G
Is there another way to jailbreak version 3.1.2 besides blackra1n?
aparently debbie42 didnt read the question.
yes there is another way to jailbreak your iphone.
you can download custom 3.1.2 firmwares that, when installed, are jailbroken. you do not need to use blackra1n.
Nov 02, 2009 | Apple iPhone 3G
IPhone 3G camera not responding
1. Backup your iPhone in iTunes and restore.
2. The 3.0.1 and 3.1.2 firmware's Blackra1n can jailbreak them.
Oct 08, 2009 | Apple iPhone Smartphone
Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
/**/ Thanks
Thiru
Jun 20, 2009 | Apple iPhone Smartphone
2 2 Jailbroken iPhone 3G locked after upgrading can it be unlocke
i am sorry i found a wesite that will possibly help you (www.webcrawler.com/fix_iphone)
i hope it works and please rate me
Mar 16, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
3,598 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
