Miele HG01 G891 SCi
When the dishwasher gets to emptying it stuck´s there. Is there a way to reset the machine? We have cleared the strainer inlet water, and cleaned the drainpump but it didn´t help.
Well to Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
If resetting not work then you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Good Luck!!
