Question about PNY Verto GeForce FX 5200, (256 MB) PCI Graphic Card
Installing GeForce 5200 on Dell Dimension 2400
Any ideas? I tried with disabling on board Intel graphic chip and still my screen comes up blank, i need help with this plz .....
  • bootiegara Nov 25, 2007
    I have the same dual vga output card but a very strange problem. It is PCI slot and have tried in two different systems. It works very well untill the windows XP welcome screen comes up. Then the screen becomes blank. It does work alright if working in BIOS, System setup, DOS etc but as soon as it goes to windows.. windows logo shows up but before going to desktop the screen becomes blank. Any suggestions/solutions pleaseeeeee. Many thanks.
  • zombie_slag Jan 23, 2009
    this is a PCI card moron. No AGP or PCIe slots on a dimension 2400, and when I install the card, winXP doesn't recognize it. Can't install the drivers and disabling the onboard gpu just leaves me with no output to my monitor. can anyone figure this out while realizing that this is a PCI card?
    Novelist:
    Scholar:
  • 167 Answers
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Posted on Nov 03, 2007
I have a Dell Vostro 400 and two video cards. Only one card will work and it is an Nvidia GeForce FX 5200.The other one is an ATI Radeon HD 2400 PRO. These are the specs from the two graphics cards:...
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
Jun 01, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
Having problems installing a Geforce fx5500 on my dell deminsion
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped  install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Feb 07, 2010 | XFX GeForce FX 5500 Graphic Card
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
Monitor going to power save mode and freezing
Hi, i have had that problem before and its wasn't the graphics card drivers, it was loose, anyway for you case go to device manager and uninstall the graphics drivers from there then restart and install then manual by updating and locate the exact location from the cd or any other location that has them.
That should help
Cheers
Apr 27, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Can a Dell Dimension 2400 take a GeForce 6600 graphics card?
This card can only Be installed in a Tower CPU. Your Card slot will not Accept this.
Jan 23, 2009 | Computers & Internet
Card not allowing more then 640x480 and 4bit colors.
If you have the option to disable on-board VGA on BIOS do it for test.
To check if you have enough power please try to boot with your CD/DVD dirves and extra HDD off.
Jan 14, 2009 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Display Problems
enable your onboard graphics and plug your monitor into the onboard. start up your pc and install any needed drivers for the secondary graphics card. right click on your desktop and go to your display properties you should see a faded out screen that has a 2 and a lit screen that has a 1 right click on the faded screen and check enabled then move your monitor cable over to the new vid card right click on the lit 1 and disable it making 2 your primary.
Aug 20, 2008 | Dell Dimension 2350 PC Desktop
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Dell monitor power down mode with Geforce GFX card install
I think maybe some how the main graphics for your pc has possibly switched to onboard. Try getting into bios F2 or DEl on boot up and highlight Advanced ChipsetFeatures and press Enter. In here make sure your AGP card is set as the Primary graphics controller. When done press ESC and 'Y' to save settings, then re-boot pc. Hope this gets you running again.
Nov 10, 2006 | Dell (M1325) (64 MB) Graphic Card
PNY Verto  GeForce  FX 5200, (256 MB) PCI Graphic Card Logo
621 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
