Dial keeps clicking around wont select a cycle, it was stopped mid cycle by accident then we tried to start at a new cycle ,since then the dial is costantly going around and the machine is full of water.
  • 31 Answers
The washer is trying to reset its self. pull the washer out put the waste pipe to floor level to empty the water <not no your floor > plumb it back in then turn it on and it will sort its self out
Posted on Jun 21, 2009
It was spinning and started jumping around. Know now it needs new shocks. BUT THEN it stopped mid cycle. Door lock light on but no further action.
IT MAY BE UR SHOCKS BUT COULD ALSO BE THE DAMPER STRAPS, THE COUNTER WEIGHTS, BALANCE SPRINGS ETC ETC U HAVE TO REMOVE PANEL OR CABINET AND HAVE A LOOK
YOU MAY BE ABLE TO UNPLUG IT A FEW MINUTES AND RESET MOTOR BOARD./
May 19, 2015 | Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
In mid cycle my daughter accidently lifted the lid to our Top Load washing machine. It did not turn on again and is sitting with water in it. What to do?
You need to reset your washer cycle. There is typically a dial that you push in and turn, then pull to start. If so, push it in and turn it to the start of a new cycle, then pull it to start the cycle. This should activate the new cycle and solve the problem.
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Ariston Margherita 1635
try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
Feb 27, 2008 | Ariston Technologies AW149NA Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
