Question about Nokia Consumer Headset
3310 not charging
  • 85 Answers
Re: 3310
When it says:
NOT CHARGING *with a stop sign*
its time for the battery to be replaced.
Nokia's 3310 Batteries should be changed every year.
Happy Holidays.
Regards. :)
Posted on Jan 02, 2008
0 characters
3 Points
When charging the red light will cycle 7 seconds on then 2 seconds off and constantly repeat this cycle. However, the instructions state when charging the red might will stay on until fully charged. What...
Sounds like battery is no good There should be symbols on charger. Normally solid light charged. Blinking. Charging. Lights back and Foward battery. No Good won't accept charge
Mar 25, 2015 | LG HBS-700 Bluetooth Headset
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Jabra sport will not charge
Same problem did you call the 800 number?
Dec 09, 2011 | Jabra Headsets
How do i charge my jabra bt150
Use the AC adapter to charge from a power socket.
The charging socket is located at the top of the headset (the wider end). When the LED is solid blue, your headset is charging. When the solid blue LED turns off, it is fully charged.
Sep 27, 2010 | Jabra BT150 Wireless Headset
MadCatz8860 Won't Charge
when you buy it for the 1st time, charge it up for double the reckemended 1st charge
Apr 19, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Cannot get the back off my nokia 3310
Press the battery button of lower back cover, push out the battery back cover
pls rate"
Dec 17, 2008 | Nokia Colorful Handsfree With Boom Mic....
Motorola H350 will not charge
There is two way you can do 1) ensure that the charger have output ( use volt meter to check or use handphone to confirm ).2) ensure the bluetooth charge contact is clear for charging ( or use contact cleaner to clear ).if you have done this two and still no charge then the battery in the bluetooth may be dead. hope it help.
Aug 20, 2007 | Motorola Mobility H350 Wireless Headset
Sony ericsson t610 is not charging
if the chocking coil that is placed bet charging fuse and charging input pin of UEM(universal energy management) is not working properly the set wont charge or else if protection anode is short circuited also device wont charge
Apr 20, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Nokia Consumer Headset Logo
116 people viewed this question
Top Nokia Headsets Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a Nokia Headset Expert? Answer questions, earn points and help others
