Question about LG 26LC2D 26 in. LCD Television
No picture when turned on - sound ok
LG26LB7 - no picture when turned on, black flickering screen. Sound seems to work OK. connections to set look ok. Is there a way of re setting the TV or do I require expert. can you please help.
    Problem Solver:
  • 10 Answers
I think that you should try playing around with some of the plugs
Posted on Jun 21, 2009
Sound no picture
When you're asking for help online, it's a good idea to provide more information. It's really hard to determine the problem without seeing the set, so tell us anything you can. Some information that may be helpful:
1) Make/model of the failing part
2) What's connected to it?
3) When did you first notice the problem? What were you doing right before the problem struck?
4) Have you seen any error messages?
5) Is the problem constant or intermittent?
6) Be specific about what you observe. In this case: Does "no picture" mean the screen is dead, or that it goes from that deep "off" black to the slightly lit black that you get when the screen is on but getting no input? Does the screen flicker? If you do something to change the input, does the screen react in any way? Is the sound normal? Do you hear anything unusual? Does the set smell OK? Feel around; is anything unusually warm?
Some troubleshooting steps to try:
1) Turn it off, then back on
2) Check cable connections; turn it off, and unplug then replug every cable coming out of it, then turn it on
3) Turn it off, disconnect anything that it's connected to, then turn it on
4) Turn it off, unplug it for a few minutes, push and hold in the power button for 30 seconds, then plug it in and turn it on
5) Swap out any cables you can
6) Swap out any accessories you can (verify that peripherals are working); in this case, what is supposed to be supplying the picture to the TV? An internal tuner? External antenna? Cable box? DVD player? If you can, take those devices to a working TV to see if they work if connected to another TV.
Give us any further info you can, including whether any of the troubleshooting steps had any effect.
Jun 02, 2015 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
I have a sanyoclt2054 picture flickers and then goes black and the sound is ok. what is wrong with this?
It is the lamp that is getting faulty, that is why you are having the flickers and the black screen.
when it is completely bad, you will be experiencing a total black screen but the sound will still be functioning.
Have the lamp replaced and the television will be okay once again.
Take care and good luck
Nov 06, 2010 | Televison & Video
P50 sound ok picture went dark but not out all the way. Made a loud noise when it happened
did you ever get a answer?
i also have a p50hdtv with a black flickering screen
but no pop and sound is still working.
May 10, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv has sound but no picture
Sounds like you have lost video somewhere in the video circuits. Possibly the picture tube could have gone bad or lost filiament voltage. You can check to see if you have high voltage by holding your bare arm close to the screen. The hairs will stand up if you have high voltage. Absence of high voltage will also cause a black screen,but the sound might not work either since on some sets the power for the sound is supplied from the same circuit as the high voltage. Stargazer
Jan 24, 2007 | RCA G36710 36" TV
LG 26LC2D 26 in. LCD Television Logo
307 people viewed this question
Computer Repairing
Computer Repairing
