Question about Intel 865G Motherboard
Thanks for your help. But I dont see any text explaining cable/connector for, only these was there: ''4-6 Power switch'', ''+2-1 HD_Led'', ''+5-1 SUS_Led'', ''+3-1 Power_Led'', nothing more. How do I know where the positive and negative of my connector? Anyway thanks for your help.
    Novelist:
  • 152 Answers
Where you see the + next to " +2-1 HD_LED" this means that the connector for the hard drive LED should be plugged onto pins 1 & 2, and that the " color " part of the conenction should be on pin 2, because pin 2 is your positive lead...
4-6 Power switch - Does not matter wich way it is plugged in, as long as it's plugged onto pin4 and pin6
+2-1 HD_Led - Hard drive LED - Pin2 is positive, pin1 negative
+5-1 SUS_Led - suspend LED - Pin5 is positive, pin1 negative
+3-1 Power_Led - Power LED - Pin3 positive, Pin1 Negative
Posted on Jun 21, 2009
Ms 7500
Orient the motherboard so we are both looking at it the same way;
Processor to the Top, black and white Ram Memory slots to the Right, white PCI slot, and black PCI Express x16 slot to the Left;
Above the white Ram Memory slots, is the 4-pin ATX +12 Volt power cable connector. Whitish, square, 4 socket hole connector.
General example of this power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Right next to it is a black header.
The Front Panel header, (Panel1)
This is the pinout,
http://h30434.www3.hp.com/t5/Desktop-Hardware/HP-Pavilion-h8z-1150-Motherboard-Headers-front-panel/td-p/1266199
Scroll down to Dave G's post.
4 pins across one side, 5 pins across the other side.
The side with 4 pins has the pins numbered EVEN.
The side with 5 pins is numbered ODD.
START on the OPPOSITE side of the missing pin.
As you can see there is -> No Pin 10.
The pin on the other end is Pin 2.
Pins 2, 4, 6, and 8. No Pin 10.
Other side;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pin 9 is N/C. Not Connected. Reserved for the factory
4) Pins 2 and 4 are for the Power On LED. (Light Emitting Diode)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
5) Pins 6 and 8 are for the Power On switch.
6) No Pin 10
Also,
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01410074/c01410074.pdf
The above is a PDF file, Illustrated Parts and Service Map, of the HP Compaq DC5850 Desktop PC.
If it doesn't work just by clicking on it, then copy it, and paste it in your browser search bar. Then press the Enter key.
[This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the link it may take up to 30 seconds, before the first page comes up ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell HP DC5850 MS-7500 AM2 SYSTEM BOARD
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
http://en.wikipedia.org/wiki/AMD_700_chipset_series#780G.2F780V
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R600_series
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
Pins 11, 12, 13, and 14 are NOT USED.
These pins are in the Orange blocks.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
These pins are in the Blue blocks.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
If the PWR ON LED is dim when the computer is on, switch the wires around.
These pins are in the Green block.
E) Pins 6 and 8 are for the Power On switch.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
Regards,
joecoolvette
Aug 10, 2012 | Gateway Computers & Internet
Need pin configuration for power switch, HDD LED, power LED, front USB, etc.
Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
17 15 13 11 9 7 5 3 1
18 16 14 12 10 8 6 4 2
Pins 1 and 3 = HD LED
Pins 2 and 4 = POWER LED
Pins 6 and 8 = POWER SWITCH
pin 14 has no
pin
Feb 02, 2010 | Compaq (283983-001) Motherboard
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
Help!
Page 26 of the below PDF should have your answers.
http://www.globalamericaninc.com/manuals/2801550.pdf
It might also be in your manual just on a different page?
Jun 21, 2009 | Intel 865G Motherboard
Simple pinout help
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
Mar 26, 2009 | Computers & Internet
49p1605 manual
Start up your computer, Hit F1 go to Bios and see which is the model number of your IBM motherboard (usually is a number like this: 8313-BU7 (example))
Then go to Lenovo.com >> Support Drivers
Select >> Desktops >> Netvista >> Model Number (put yours) >> OS
And get the drivers and all the info about your machine.
Please dont forget to rate my help! :-) Have a great day!
May 01, 2008 | IBM (49P1605) Motherboard
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Intel 865G Motherboard Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
