Question about HP ScanJet 2400 Flatbed Scanner
LAmp stuck up
When i power on the scanner the lamp not working it will tend to stuck up
  • 50 Answers
Make sure that the lock switch is set to unlock.
Look for it on the scanner body.
If it is unlocked, then unfortunately the scanner is probably faulty.
Hope I helped,
tom
Posted on Jun 21, 2009
Unit will not power up
the lamp may be faulty needs replacement, another culprit is the color wheel when worn out they tend to get stuck and cant spin hence the clicks as tries to spin needs replacement most color wheels come inbuilt in the light engine u will need a tech to replace it and u are good to go remeber the lamp cant turn on if the color wheel is stuck cos its the one that syncrinizes with dmd board which in turn activates the ballast board to fire or light the lamp
Jul 15, 2013 | Sony BRAVIA KDL-V40XBR1 Television
Sir, my canon ir 400 machine shows an error code 803. how can i solve the my problem. give detailed information to my mail. thanking u.
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
Jan 27, 2011 | Canon imageRUNNER 400S Copier
Where can I buy spare parts? i need a new lamp.
I have a Agfa DuoScan F40 Flatbed Scanner. It appears that the scanning function is not working. Light is not turn on.Blank white paper as a result.
I wonder if we could somehow mod the scanner lamp since it is nearly impossible for us to buy the scanner lamp nowdays,even Agfa support say so.
The function of this lamp is similiar to a torchlight.It will brighten the document that we want to scan during the scanning proces.What if somehow we manage to use other device other than the lamp it self like superbright LED(20 watts) or another lamp scanner from dead scanner macine.I think it will work.Anyone care to comment....
Jan 11, 2011 | Agfa DuoScan F40 Flatbed Scanner
MFC8860DN SAY'S SCANNER LOCKED?? WHAT'S THE FIX??
Hello my friend.If you open the scanners door under the document cover is one switch that locks and unlocks the scanner.Move it to the position that shows that is unlocked.If this doesnt work it means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This should fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remove the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable . After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp more into the scanning area and repeat until works.
Feb 09, 2010 | Brother MFC-8860DN Printer
Modle 5222, scanner error?? any suggestions?
sure you lamp lights up when machine is powered on. open the top cover, turn power on. lamp should light and scanner should move. if either of these do not happen you will need to replace parts. if the lamp lights and the scanner moves your ccd could be bad. you may need a service tech. if the lamp does not light it is your problem. lamp, power supply, ballest, or main pcb could be the problem
Oct 21, 2009 | Lanier 1205 Copier
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Scanner
SIR, YOU HAVE MENTIONED THAT SCANNER LAMP IS NOT GLOWING AND THE SCANNER IS WORKING PROPERLY;THE STEP THAT YOU HAVE TO TAKE ARE: 1.OPEN THE SCANNER AND SEE IF THE CARD IN SCANNING UNIT IS ALL RIGHT NOTHING IS BURNT. 2.IF EVERYTHING FINE IN THE LOGIC CARD OF SCANNING UNIT YOU CAN HAVE TO REPLACE  THE LAMP .
Aug 29, 2008 | HP ScanJet 2300C Flatbed Scanner
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    HP ScanJet 2400 Flatbed Scanner Logo
    280 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
