Question about Bburago Citroen C6 Diecast Model
Grinding noise when cornering - Bburago Citroen C6 Diecast Model
  • 30 Answers
If you are turning around the corner you put much stress on the shocks and bearings check them out easy way to check the bearing jack up the car and wiggle the wheel if you feel it wiggle then its the bearing otherwise the shocks have gone
Posted on Jun 21, 2009
Why do I hear grinding noises while driving?
Hit in the rear axle may have damaged bearings or brake parts. Jack up the side you hear noise from, put on stand, then have helper rotate wheel while you look underneath and listen to see where noise is coming from. Use length of old fuel or heater hose, one end in ear, to locate exactly where noise comes from.
May 27, 2015 | 1996 Jeep Cherokee Country
I have just replaced my cv joints in the front , and now there is a grinding sound when I am turning a corner?
Did you completely remove the shafts to repair/replace the cv joints. If so then one shaft may be longer than the other and binding up on cornering. Check that the wheel bearings have been properly adjusted . IF you replaced the 1/2 joint on the shaft still in the transmission the it may not have been assembled properly (cage in wrong) and this is causing a problem. Either way I suggest that you seek an accredited service shop to check out the noise before any damage is done.
Apr 22, 2014 | 2012 Subaru Legacy 2.5i Sedan 2.5L 4-cyl....
If your vehicle has front wheel drive you have to inspect the outer CV boots on the drive axles. If they are ripped then they are probably the culprit for the noise. Check the side that sounds like the noise is cominf from.
Mar 23, 2014 | Cars & Trucks
Dragging feeling in rear, grinding noise
I NEED TO KNOW WHICH JOINTS U REPLACED EXACTLY AND WHEN.IS THET NOISE COMING WITH THE STEERING WHEEL TURNED ALL THE WAY TO ONE DIRECTION?DO U FEEL LIKE SOMETHING IS KICKING THE CAR?IF SO LET ME KNOW
Mar 09, 2014 | Volkswagen Touareg Cars & Trucks
What is causing my explorer to **** & clunk with a loud grinding or rubbing noise when i turn corners?
Sounds like you have either ball joint issues, or problems with the CV joints. The other possibility is a problem in the transfer case causing the front axle to bind. You can physically look at the CV joint boots to see if they are torn open and many times you can grab onto the axle and give it a good tug to see if it will move..it should not.
Mar 07, 2014 | 2002 Ford Explorer
1997 dodge ram pu 4x4, when I turn corners or start moving I hear a grinding noise coming from the rear end area. Any idea what would cause this and estimated repair?
most common cause is rear pads sticking (rust) and when you move, it has to break the rust from the rotor,hence the grinding noise.as long as it only does it when you start moving or turn first thing do not worry.....
Aug 11, 2010 | 1997 Dodge Ram 1500 Club Cab
My 1997 Honda Accord makes a grinding noise when in motion. When I press on the brakes it stops, when I release the brakes it starts again. The grinding noise continues pretty consistantly when in motion,...
Sounds like a bad wheel hub. Or it could be just the brakes. Can you tell which corner it is coming from? Can you jack up that corner and spin the wheel? Wheel hub job about $400 brakes about $200 or less. Good luck
Oct 22, 2017 | 1997 Honda Accord
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
Service manual
When you say the gears are not messing, what exactly do you mean.
Do you actually hear gears grinding, or are you just having an issue with magenta not printing properly.
if you hear grinding, where is the noise coming from? at the top right corner by the toner, or on the right side in the middle?
In either case, if you actually hear a grinding noise, this would require replacement parts to repair as these are not consumable user replaceable items.
Sep 04, 2008 | Dell 5100cn Laser Printer
Bburago Citroen C6 Diecast Model Logo
143 people viewed this question
Top Bburago Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Bburago Toy Expert? Answer questions, earn points and help others
