Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
I have a SImple Tech/Simple Drive(150GB) FAILURE-
I have a SImple Tech/Simple Drive(150GB) and as of 2 days ago when I plugged it in,and turned it on the blue light that once would blink and then turn off- stays on and then a message that reads something to the effect that the disk can't be read and I can either initialize/ignore/eject. So far I have not initialized because I am hoping I can rescue the data.
The model # is 96300-40001-001
thanks for ANY assistance.
  • 58 Answers
There are many reasons why a drive may fail, if the data on it is very important you should not try to fix it yourself, but rather take the drive to a reputable data recovery service, you can search on the net for one near you. If the data is not so important and you want to try to fix it yourself, you can download a data recovery program such as Zar from www.z-a-recovery.com These programs will normally try to fix the problem and if any data can be recovered, they will let you know. You will then need to buy the program to actually recover the data
Posted on Jun 21, 2009
Brake Lights
simple things first,1. bulb failure..2.switch failure..3 fuse gone.
Jun 07, 2010 | 2003 Nissan Altima
COMPUTER DOES NOT RECOGNIZED SIMPLETECH EXTERNAL HD
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
I posted last year when I had this problem (Sept. '08 I think) and I just received an e-mail because when you guys posted today I got an e-mail that the topic updated. After my initail post I solved my problem, but I forgot to come back and post the solution, so here is what happened with mine...
This drive has a manufacturers default. If you don't use it for a while...if you detach it frequently...and/or when you reach a certain amount of space used it requires a certain power source to be used. There is no warning, and this is not stated anywhere, however I did contact the company directly. This problem occurs when the drive is not plugged into the main USB Port in the back/side of your machine. You cannot use a hub or external USB source for power. When you reach any one (or all) of the three points that trigger the drive to stop working the only thing that will enable the device to work properly again is for it to always be plugged into a main port. They are the only ports that have enough power to support the drive. This goes for laptops as well. When using a laptop, you cannot plug the drive into a mini hub, laptop riser, cooling fan, etc., it has to be one of the main ports or there will not be enough power to run the drive.
If your drive has already stopped working, all that is needed to enable it again is to properly shut down and disconnect it and your computer. Then reconnect and power up just like you would initialize it if it were new. As long as it is plugged into a main port you should have no problems. All your data should be fine and you should have no more problems.
Personally, I have had smooth sailing ever since we determined that this was the problem. I hope this helps some of you. Good Luck!!!
Aug 28, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Simple Tech 160GB thinks its a DVD drive...
My friend if you try to format the drive u will loose all the data on that drive. I can help you format the drive but you will loose data.
Jun 16, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple drive external backup
You need to use the Storage Sync program provided with the drive. You can get the latest version at the Simple Tech website
Sep 20, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
386 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
