Question about BenQ Computers & Internet
Laptop connected to TV via 23pin cable and setup
Laptop connected to TV via 23pin cable and setup to use the TV screen as a monitor. How do I make the laptop use the built-in TV speakers for music and discontinue its own speakers?
  • iananddesley Jun 22, 2009
    Thanks Tom.
    I have no doubt you are right. I currently am using a cable from the laptop to a pair of PC speakers and it is satisfactory. Wasn't too sure which connection to use on the TV - there seem to be lots of different ones and all with different types of fittings so decided the computer type speakers would do the job and probably be as good as the TV ones anyway.
  • 50 Answers
You have to connect the laptop to the TV by using the headphone jack on the laptop.
Only then, will the sound be sent over to the TV, and automatically the speakers on the laptop will stop working.
Get a cable to connect them from the headphone jack to an appropriate input on the TV.
Hope I helped,
Tom
Posted on Jun 21, 2009
How to connect laptop to my tv
The only output you have on this laptop is a VGA monitor connection.
See manual.
HP Compaq 6820s Notebook PC QuickSpecs c04151583 pdf
You need a TV with a PC connection to view the video.
You will also have to connect up the speaker sockets t the TV audio in via a cable, that depends on the TV.
Feb 01, 2014 | HP Compaq 6820s Business Notebook
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
How to i connect my laptop into television with high definition multimedia interface
First what you need is a HDMI cable.
Second look for HDMI port at the side of your laptop. (It may not be the model of your laptop.)
Third look for the HDMI port on you T.V. (It may not also the model of your T.V.)
After confirming those connection on your T.V. and Laptop, you can just the HDMI cable to connect you Laptop to T.V. Also you need to choose HDMI on your T.V. settings and for your Laptop you can just switch the display by pressing FN+F4 or F5.
Hope It helps.
May 14, 2011 | Compaq Presario CQ60-204NR Notebook
When connecting my Toshiba laptop to my Toshiba T.V. model type 20WLT56B I can't seem to get the laptop screen fully onto the T.V. screen. It seems to be a screen within screen. Any ideas.
You may have to set either the aspect ratio or resolution from the setup menu of the TV or set the external VGA monitor resolution via the Control Panel (if the OS is Windows).
Dec 14, 2010 | Computers & Internet
I've been trying to use s-video cable to connect
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Mar 06, 2010 | Acer Aspire 3690-2196 Notebook
I have a dell GX280 and I tried to connect it to a Olevia LCD TV but I have a problem to do so. I connect it via VGA cable. When I started the PC I could see TV display Windows logon and show PC is...
Lower you screen resoloution to 800x600 to start with. Also you must setup mutimonitor, correctly.
Feb 09, 2010 | Dell OptiPlex GX280 PC Desktop
Cant connect tv to laptop via htmi cable
You need to use the RGB input port on the TV
May 01, 2017 | LG 47LG50 47 in. LCD HDTV
Connect tv to computer
Be sure to enable the second screen through the windows display settings. Right click on the desktop background and select personalize (VIsta) or Properties (XP). Click on the settings menu (lower down on Vista, a tab on the right for XP) and look at the monitor setup. After you are connected via cable to the TV, go there, click on the second screen and select "enable this monitor", "extend desktop onto this monitor" or something of the like. Oftentimes it will not do it if you are not already physically plugged in so ensure that you do that first.
Aug 26, 2009 | HP Pavilion Elite M9150F Desktop PC
Laptop to TV
I dont believe that you can hook that model up to a TV you have to have a certin video output and it also would depend on your tv as well. But i am about 100% sure that series does not have the output you need you usally can connect via S-cable
Dec 04, 2008 | Dell Inspiron 2200 PC Notebook
Computers & Internet Logo
284 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
