Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
How to remove spray arm - KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
2 Suggested Answers
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: spray arm not attached
You may have stripped the threads on the spray arm or spray arm support. I believe the threads are reverse-threaded and since they are plastic, can easily be stripped if turned in the wrong direction. This has happened to me before. The solution is to replace the lower wash arm and spray arm support. You can find the parts at repairclinic.com. Just type in you model number and look for item numbers 830883 (spray arm support) and 9040141 (lower wash arm). You may also want to check out searspartsdirect.com as well. The parts will be located under the "Lower Washarm and Strainer Parts" section. The two sites do offer comparable pricing. Post back if you need further assistance. I hope this helps you.
Posted on May 04, 2008
Top spray arm doesn't spin
The filters are probably plugged. This will require removing the lower spray arm and cleaning the screens or its possible your not getting enough water in the dishwasher which will cause th upper spray arm to not turn
Feb 10, 2018 | Maytag Dishwashers
PDW7800 lower spray arm making clunking sound
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Apr 14, 2014 | GE 24 in. Profile PDW7800 Built-in...
Top spray arms dont work.
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Jun 05, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Sprayer is clogged.
REMOVE SPRAY ARMS AND REMOVE DEBRIS. THEN REASSEMBLE REMEMBER THE ORDER OF PARTS REMOVABLE.
Feb 26, 2010 | Dishwashers
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
Noise when spraying
The wash arm(spray arm) is not a tight fitting item,as for the noise the when spraying have a look at the spray arms the are a few holes on each side and top and bottom of each arm,you will need to remove the arms of possible they normally have a quik release system where you push two small fingers together and the arm releases,then inspect these holes and you will probebly find that some are blocked this cuases a uneven flow of water and thus makes the arm rotate un even and make a noise if you find there is food of sorts in these holes remove and put the arms back and that should take care of the increased noise.
Feb 05, 2009 | GE 24 in. GSD2030Z Built-in Dishwasher
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
