Question about Dell U0636 Mouse
Dell Studio 15 laptop mouse does not work at start up.
The mouse (Dell Premium Optical Mouse) does not work when the Laptop is started. MAybe after 5 -10 minutes it miraculously responds.
The red light is not on immediately.
Seems like a slow start up issue.
  • msutton315 Jun 21, 2009
    But then if I wanted to use the internal mouse I'd have to go into Control panel again.
    This sounds like a work around rather than a permanent fix, don't you think.
  • Kreesha Fletcher
    Kreesha Fletcher May 11, 2010
    It sounds to me like the mouse buillt into your laptop is conflicting with the Dell external mouse. If you go into control panel and click on mouse, you can disable your built-in mouse. Restart your computer with the USB mouse plugged in and see if that does the trick. I would be surprised if it does not. On the off chance it doesn't work, you will have to enable your built-in mouse and we can check to see if there are any additional conflicts happening through your hardware profiles in the system area of control panel.
  • 192 Answers
Posted on Jun 21, 2009
  • Kreesha Fletcher
    Kreesha Fletcher Jun 21, 2009
    No, I don't. There is no permanent fix if your mice are conflicting. Work around?? There's no way to fix a conflict except to remove the conflict...
    How do I know? I started out with Windows 3.1 (well, dos actually) and have tutored and managed a 300 head office through every single version of Windows. Now, if a tech tells you different (barring the fact that you may just have a faulty mouse) I would have to see the result. I feel anything one does aside from removing the conflict would be the "workaround" But hey, this is all free advice anyway, so I guess your best relu of thumb is listen to what makes you feel better about yourself.
  • Anonymous Apr 23, 2018
    baring a bad mouse, .....
    It's clear as day the OP hates the internal pad. ok?
    wow WORKAROUND FEAR.
    ooooooooahhhhhhhhh cry, run.....
    this post above is full of lies./fear..?
    if 2 mice are present , that is the conflict.
    disabling one is not a workaround ! sorry.
    It's not a GERRYRIG,(ww-2 slang) (as in Gerry Cans to, for fuel)
    the conflict is the lazy persons right thumb.
    it hits the pad, (we all hate that,)
    so cut off thumb (haha) or disable the pad.
    It's just 1 feature, and like all features in the PC and windows,all things can be disabled. (that is why they put a check box there, not to cause FEAR but to DO AS YOU WANT)
    oh my gawd.
    Habit-Forming:
    New Friend:
  • 30 Answers
If your dell mouse is not working then there is no any other option to purchase new mouse. Mostly time I have seen if you get your mouse repaired then few days later, that would be damaged again.
Posted on Apr 16, 2018
    sohpia wow. and wrong. 9 year later?
    here is the correct answers, in all cases.
    1: new mouse (captain obvious to the max)no?
    2: turn off the internal pad mouse is device manager and all external mice work right.
    3: up date the internal mouse driver for the newer feature called, (I have it)
    "auto turn off track pad with USB mouse connected" (x)
    4: yes a mouse external can be cleaned, (hint inside if gets packed in lint and optics go blind) or replace or repair the broken cable.
    all techs, worth salt can do that but labor is 10x more that $3 mouse and will laugh at you. or get rich toss coin.
    5: the wireless keyboard and the mouse both have a battery, replace it.
    6: the external mouse needs pad buy one or it will jump like mad.
    7: The kids sabotaged the mouse. gum on red lens there? ha ha, got you.
    8 The USB port is bad try the next one.
    9. the usb port driver is corrupted got XP sure it infected as sll are now.
    10,. im sure there is more, sure.
    robin from 1966 posts to 2009,.
    wow. "HOLY time warp batman."
SOURCE:
I have a Dell Studio Laptop. I have to move the curser at the right hand corner to scroll the page?
Find your way into control panel and check mouse settings I believe the middle mouse button is adjusted there. The details are different with each brand of mouse but this should point you in the right direction.
Jun 17, 2014 | Dell Studio 15 Laptop
Dell touchpad tab gone from mouse settings. tried installing driver with no luck. Also tried uninstalling and reinstalling driver.
Customizing the Touch Pad
You can use the Mouse Properties window to disable the touch pad or adjust
the touch pad settings.
1 Click Start , and then click Control Panel.
2 Click Hardware and Sound.
3 Click Keyboard.
4 In the Mouse Properties window:
• Click the Device Select tab to disable the touch pad.
• Click the Touch Pad tab to adjust touch pad settings.
5 Click OK to save the settings and close the window.
Apr 06, 2010 | Dell Studio 17 Laptop
Just changed batteries in my wireless mouse.
there will be a button on your mouse. Press it to sync the settings with your laptop and it should start to work.
or else
click start
right click my computer
properties
hardware
device manager
?mouse and keyboard
scan for hardware changes
Feb 26, 2010 | Dell Wireless Keyboard Optical Mouse w0147
The mouse touchpad on my Studio 1569 is not very sensitive. I can hardly get the mouse to move and I can't find where to adjust. The OS is windows 7.
Windows 7 loves to hide these things. unfortunately, this is one that Microsoft forgot to make hard to find..
Start -> Control Panel -> Mouse -> /Pointer Options\ and change the level as needed...
If the mouse won't reach it fast enough, use [Tab] to jump to the scroller, then use the left and right arrows to change it..
Depending on how dirty the corners of the touchpad are, they may need to be cleaned. DO NOT SPRAY IT WITH CLEANER. Find a cloth, apply cleaning solution to cloth lightly, then wipe area, and dry. anything stuck in the corners will degrade the mouse's response.
If you have ever opened the case, be sure to push the wire back in carefully and as far as it was designed to go, otherwise bad connections (resistance) will not allow it to be used fully.
Good luck.
(Keep in mind, I did not just give you permission to open your laptop. Very delicate on the inside, and painful if you have never done it before.)
Feb 25, 2010 | Dell Studio 15 Laptop
Dell studio 15-cursor moves at random when typing...
these is a mouse config or drivers defective, reinstall mouse drivers, or check for virus/spyware infestation. check with online antivirus, like norton,....
Dec 20, 2009 | Dell Studio 15 Laptop
I use dell inspiron 1440. today onwards the bt travel mouse does not connect to my laptop. how i rectify this problem
reinstal the driver for it and should work or check in start-my computer-right click manage-device manager -action -scan for hardware changes.
Dec 09, 2009 | Dell 5-Button Bluetooth Travel Mouse -...
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Dell U0636 Mouse Logo
683 people viewed this question
Ekse
Clive
Clive
