Question about Car Audio & Video
Electrics on my bike are all over the place, lights , indicators , etc, on my honda cb 125rs motor-bike
  • 44 Answers
What is the problem. some one has rewired the bike and got them all mixed up?
Posted on Jun 27, 2009
Sorry thought this was a honda cb1300 site, what oil for this bike 2005 model, thanks
We answer Motorcycle questions all the time
Parts & Specifications: HONDA CB 1300 ' Louis Motorcycle & Leisure
https://www.louis.eu > Service > All about bikes > Bike database
  1. Cached
  2. Similar
Find technical specifications, spare parts and accessories for HONDA CB 1300 at Louis Bike-Database. ... ENGINE OIL. Exclusively from Louis! HC synthetic ...
CB1300 SB Changing engine oil - YouTube
2q==? 1:32 https://www.youtube.com/watch?v=9v8LPIDT_RA Apr 24, 2017 - Uploaded by CHANNEL SPM 30:16. Honda cb 1300 gold edition road - Duration: 2:01. ????? ??????????? 2,352 views · 2:01 · How to Change Your ...
What motor oil is best for HONDA CB 1300. Motor oil by motorcycle ...
oil4motor.com/en/moto-oil/HONDA/CB-1300-(2009-)/1557
  1. Cached
What motor oil is best for your HONDA CB 1300 (2009-). How much motor oil does your motorcycle holds. How often you should change motor oil. What oil is ...
Engine oil for 4 stroke motorcycle HONDA CB 1300 ... - www.rrd ...
www.rrd-preparation.com/en/8306-huile-moteur-4-temps-moto-honda-cb-1300-
  1. Cached
Here you will find all oils 4 stroke motorcycle engine HONDA CB 1300 ... and others. All ranks, from the simplest motor racing oil has the most to protect the ...
Oil for Honda CB CB 1300 /A/S/SA (2005-2014). Which oil is the best ...
https://www.kroon-oil.com/en/product-recommendation/.../honda/.../cb-1300.../43134...
  1. Cached
Which oil is best for your Honda CB CB 1300 /A/S/SA (2005-2014)? Complete professional advice, including motor oil, gearbox oil (transaxle) and lubricants for ...
May 17, 2018 | Honda Motorcycles
2005 model, what make of oil do you recommend please?
  1. Cached
  2. Similar
  1. Cached
  1. Cached
  1. Cached
May 17, 2018 | Cars & Trucks
Push starter button, headlight dims, no starter motor, etc.
Yes, LED turn signal lights require a flasher rated for LED's. They are available in auto parts stores.
As far as the now start goes, double check all wiring, making sure all the positives and all the negatives are correct. Check the ground wire from the battery. Make sure the connections are tight.
May 07, 2014 | 1995 Honda CB 750 Nighthawk
2011 Honda CB Unicorn Dazzler rebuild starter motor
Hi, Sachin for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.marathonandmore.com/honda-unicorn-bike-service-manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Honda CB Unicorn Dazzler 2011
Honda Unicorn Wikipedia the free encyclopedia
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 15, 2013 | 2011 Honda CB Unicorn Dazzler
Honda 900 Custom CB 1982,if there should a problem with the OIL PRESSURE what alarm indicator will there, a light a buzz and where is this indicator located at. This not a question and the AIR...
As far as i know your older bike works like my new one. Where the only indicator is a red light that comes on in the speedo. Check the oil window on the right side of your engine for oil level. What do you mean air pressure? If its the tires it will be written on the side of the tire.
Sep 09, 2013 | Honda Motorcycles
2001 Honda CB 125 T no electrical power
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
Bike wont start no lights or anything Page 2 Honda Motorcycles FireBlades...
No electrical power
Honda CB125 Service Manual
Aug 07, 2013 | 2001 Honda CB 125 T
Honda cb250 no start
check battery voltage,then battery voltage drop at starter relay [solenoid] if battery is good replace relay but make sure all connection are good
Jul 02, 2009 | 1998 Honda CB 250 Nighthawk
92 honda cb 750, oil light will not go out, bike won't start
Look around the engine oil drain plug and fill area and see if there is an electric sending unit( small plug with a prong for a wire) that is screwed into the engine if so check to see if its unplugged / could be a low oil cut off switch that kills all power to the ignition if the oil is to low ( or the wire is unplugged)
Jun 03, 2009 | 1994 Honda CB 750 Nighthawk
What is a LOOM electrics for a honda cb360??? what is it for what does it do?? if you can, can you send a picture thanks
the loom refers to the whole wiring harness for your bike, without it your bike will be useless
Apr 01, 2009 | 1972 Honda CB 250
Motorcycle honda cg 110 will not run without choke on
make sure you have air filter. raise the needle some so you get more gas.
Feb 24, 2009 | 1974 Honda CB 100
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
