Question about Compaq Presario M2000 Notebook
Recently repaired compaq presario laptop has startup issues
I recently repaired a Compaq Presario laptop, but when I finished and pressed the power on button the screen says NTLDR missing, and when I use esc to setup windows it fails and says dac960nt.sys is corrupted.
******** and your laptop this link is full of **** do u want if yes bring your sister and when i **** her then i will till you what to do ******** man
john
Posted on Jun 21, 2009
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
My Compaq Presario F756nr will not turn on. The b...
Having the same issue. Did you find a solution yet?
May 20, 2010 | HP Compaq Presario F756NR Notebook
Compaq presario f560us will not come to life
It is due to one or more faulty components on the motherboard. You have nothing to do unless you are a laptop technician.If you can do chiplevel repairing I can further assist you as I am a chip level technician.Contact me. Make a comment for this.
Mar 08, 2010 | HP Compaq Presario F560US Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Dvd blank burning file problem
please uninstall software and reinstall it agai.
Jul 14, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario F700 Laptop power up issue
Remove your cpu/gpu heatsink, apply a ermal bonding, this will prevent shut off because of cpu/gpu overheating(chipset detects temperature faulty in the firsts seconds of operating your laptop), if this didnt resolve your problem, naybe and issue with your Mobo.
Thanks
Please leave feedback
vcrtech
Apr 27, 2009 | Compaq Presario 700 470024-192 Notebook
Problem to redeem the gift offer for compaq presario laptop
HAVE YOU REGISTERED YOUR PRODUCT ONLINE..
IF YES CHECK STATUS
IF YOU HAVE NOT REGISTERED GO TO OFFICIAL WEBSITE & REGISTER YOUR PRODUCT
TAKE CARE
Jan 06, 2009 | Compaq Presario Notebook
Compaq Presario M2000 Notebook Logo
107 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
