Question about Canon BJC 250 X. Files InkJet Printer
My page will print out, but the text and graphics are so incomplete that you can't make out anything. I tried the printer troubleshooter and it was unable to solve my problem. I refilled the ink cartridge and I don't know what else to do.
SOURCE: Canon BJC 85 printer
Posted on Feb 15, 2008
SOURCE: Refill hp 74 ink cartridge
I found a guide that worked for me:
Good luck! Mike
Posted on Jun 18, 2008
SOURCE: Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Posted on Aug 23, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
SOURCE: we had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Posted on Mar 13, 2009
  • 24 Answers
SOURCE: How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Posted on Jul 25, 2009
0 characters
1 Points
Printer not able to print?
Printer Keeps flashing green light
Mar 31, 2010 | Canon BJC 250 InkJet Printer
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
My canon bj f890 has no supporting cd rom in my computer so i can not use my printer driver.
download the driver and install it
driver CLBP 360 PS v2.02 Print Drivers
Support Driver for
Canon i250,i255,i320,i350,i355,pixma ip1000/1500, 1200/1700
  2. Canon i850, i950, S600
  3. Canon S450 Printer
  4. Canon BJC-2000 BJC-2100 Series
  5. Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265
  6. Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650
  7. Canon BJC-5000
  8. Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620
  9. Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500
  10. Canon BJC-600 BJC-600e BJC-610 BJC-620
  11. Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
  12. Canon BJ-30 BJC-35v BJC-70 F14 Error Reset
  13. Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520
  14. Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above
  15. Canon S900, S820, S750, S520
  16. Canon S9000
  17. Canon MPC190
Jun 24, 2009 | Printers & Copiers
I would like to know how I can stop my printer from printing, without messing the printer up. There are times, that I can see that it is printing more than I wanted, and would like to know how to stop it...
in printing preferences or when you right click on something and and select print , then on that window there is a selection for page 1 to page ##'s , just change it to from "page 1 to page 1" for just the present page or for more pages just change the "to pages"numbers
Nov 30, 2008 | Canon Printers & Copiers
Canon bjc-3000 is not printing
Has the software for the printer been installed in your computer? Sorry if this sounds like a silly question, but I did the same thing, and it turned out I hadn't installed the software yet so it didn't recognize the printer.
Nov 16, 2008 | Canon BJC 3000 InkJet Printer
Vista + cannon BJC 250 = error
Go to
and try the XP driver. If this doesn't work, you may not be able to interface this printer to Vista.
Let me know if this works.
May 30, 2008 | Canon BJC 250 InkJet Printer
Canon BJC-250 Printer may need to add the printer, again, after removing it. Also, did the new dell Vista disk for drivers and utilities come with? I'd advise going to Canon's page, and getting a more recent driver. The old disk from Dell or Canon, MAY NOT have the most recent driver set. Also, if you're using the print manager, that's a new download, for certain.
Feb 06, 2008 | Canon BJC 250 X. Files InkJet Printer
Canon BJC 250 printer driver
Canon Web Site for Printers.
Check the Vista internal list.
Go to Printers/Faxes
Click on Install Printer
When you get select from CD or list take 'List'
Go  to Canon
Select the Model
Click OK
Job Done
Oct 22, 2007 | Canon BJC 250 InkJet Printer
Canon BJC 250 X. Files InkJet Printer Logo
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
