Question about Intel 865G Motherboard
Help! I cant figure out where to connect my power switch and other reset and led connector to my motherboard. The description found in my motherboard seems not clear. ''4-6 Power switch'', ''+2-1 HD_Led'', ''+5-1 SUS_Led'', ''+3-1 Power_Led'', nothing more. The pin arrangement look like this [::::.::] blank means w/o pin.
  • 71 Answers
Look at your front panel connector that goes to your motherboard, there should be a small text there explaining what is the cable/connector for.
For Power Switch there might be "PWR" text, for Reset Switch, there might be "RST", etc.
Now you have to plug the connector to your motherboard pin as you draw above.
At the pin location, look for pin with "white triangle drawing" that should be pin number 1.
While for 4-6 Power Switch thats mean you have to put the Power Switch Connector to pin number 4-6.
For +2-1 HD Led, you have to put positive(+) connector to pin number 2 and negative (-) to pin number 1
and so on ... give it a try ...
Posted on Jun 21, 2009
  • 39 Answers
Page 26 of the below PDF should have your answers.
http://www.globalamericaninc.com/manuals/2801550.pdf
It might also be in your manual just on a different page?
2 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: Pls. Help! I can't figure out where to connect my
1 -3 -5 -7 in upper and
2 -4 -6 -8 in lower line
then coonect as above
How to connect pwrswitch, pwrLED, IDE-LED, reset,
you will need a magnifying glass but theres a row of pins that are there to connect the power /all switches near one corner of the board and won;t have slots for all the lights you want to hook up ! just the function switches only!
Jan 13, 2010 | ASUS P5GC-MX/1333 Motherboard
http://www.motherboards.org/files/manuals/1/p4bmx-101.pdf
Here is the manual for this motherboard, and it shows you the pinout for the power switch, reset switch, power LED, HDD LED, and speaker.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Computers & Internet
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 18, 2009 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
CONNECTOR PROBLEM
Usually the connectors will be marked as in the picture, indicating their usage. 07471ce.jpgIf your connectors do not have a label printed on them you can figure out the important ones. You will have a pair of connectors each for the power switch, the reset switch, the power LED and the hard drive LED.
The two pairs of wires used for the switches are the important ones. They can be identified with a circuit tester or multimeter (Check for resistance/Ohms). When they are pressed, the meter should indicate a connection across the two wires. In the case of the power switch if it's a really old case it will toggle on and off, so watch for the continuity to change when you press it. Otherwise the reset and power switches will only register a connection when pressed, and revert to an open circuit when released. Use your multimeter to identify which pair reacts to which swtich, and label them with some masking tape and a sharpie (or equivalent way).
As long as you identify these two and connect them correctly you'll be okay. The LEDs are not essential to booting your system and you can figure them out later. LEDs have to be connected the correct way around (usually the white wire is negative), while the switches don't matter which way they are connected as long as it's to the correct two pins. You can connect the LEDs and see which ones light up on your panel to determine which is connected where. If your power-on LED lights when there's hard drive activity, then you know that the connector plugged into the pins for HDD LED is the wires for the power LED, and so forth.
Hope this helps.
Please rate my answer.
Jan 01, 2009 | Asrock P4i65GV Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
Intel 865G Motherboard Logo
230 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
