Question about Linksys Wireless-N WRT150N Router
Conect to other compuerts in the home
MY LINKSYS WRT150N IS HOOKED UP TO ONE COMPUTER AND IS WORKING FINE BUT I HAVE 2 OTHER LAP TOPS AND A PS3 HOW CAN I GET WIRELESS SIGNAL ON THEM FROM THE LINKSYS
    Scholar:
  • 68 Answers
The way you worded the question, suggests a bit of confusion that you may have "My Linksys WRT150N is hooked up to one computer". Although once working it may be convenient to think of it that way, the router makes the network available and sets the rules for the network. Then, it is up to the individual computers to connect to it by complying with those rules.
I'm using a WRT160N, so I have to reference it, but I believe the tabs and options on the WRT150N are very close to the same thing. First, take a look at the router to see what it's rules are. The default address for the router is http://192.168.1.1. Type that into your browser (or copy/paste it). You'll get a signon screen. The default is user name left blank and password is admin. On some you need to type admin into both fields.
That will put you in the setup screen. Look halfway down the screen to Maximum Number of Users and make sure it is large enough - 3 would work for the network you describe, but within reason, a bigger number (say, if friends stop by) is good. I use a minimum of 10 and a maximum of 50.
Then click the Wireless tab (the second tab) and look at the settings. For Network Mode, I recommend Mixed. If you happen to have selected Wireless N only and your other systems are Wireless G, they can't connect. Make sure you have a network name. It doesn't matter what it is as long as (1) you know what it is and (2) it is different from any neighbors who happen to be in range.
Then go to the Wireless Security sub tab. See what your settings are on this page. I recommend WEP, 104/128 bit, and a complex hexidecimal key in Key 1. Either just note the values that are there, or set them the way I suggest.
Go to the next sub tab, Wireless MAC Filter. This lets you set up which PCs can connect to the router and which can't by MAC (a unique identifyer). I recommend disabling this by clicking disabled at the top of the page. That should handle the understanding of the setup on the router side. There's other things that can be set, but most people just leave them alone.
Then for your other computers and your PS3, go into their wireless setup and set the values that you now know are in the router. If you run into trouble doing this, post again with what you did and what happened.
Posted on Jun 21, 2009
    President:
  • 1,383 Answers
Your current computer is connected with ethernet cable of wireless.
If it is wireless then no problem your wi fi is ebaled in router.
then check on both laptop that wi fi netwrk adapter drivers are installed.
Also check in both laptop there wireless switch is on.
Then you can easily find signal form router and u can find netwrok.
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
Internet shuts off why?
First try doing a complete reset on your Router, and then give the wireless a new name and password. Do Not inter any old/same info. Start fresh
Nov 26, 2017 | Linksys WRT110 Wireless Router
My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
Dec 27, 2009 | Linksys Wireless-N WRT150N Router
Can't get wireless internet to work on dell laptop
May I suggest you give Network Magic a try at solving your connectivity problems. Free to download and evaluate, you may well find it is well worth the couple $ for the 5 full licenses. Get it here: http://www.purenetworks.com/nmlp/home-networking.php?gclid=CPua-J-J1J4CFVw55QodUi_Nrw&src=google&kw=network+magic+download
In addition to connectivity, NM will aid you with security and sharing as well as other fine features.
Thanks for posting at FixYa.com
Oct 01, 2009 | Linksys Wireless-G Broadband Router
In my WRT150N all light ethernet light are on and also internet .. and is nothing conected to it.. onle power cable
This is a sogn of a bad router already, first thing to do here is to press and hold the reset bitton of the router for 30 seconds and then power it off for 10 seconds and then check if its working fine now, but if still the same problem replace the router already...
Aug 09, 2009 | Linksys Wireless-N WRT150N Router
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Linksys router vs. hp computer
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Dec 28, 2008 | Linksys Wireless-G WRT54G Router
Linksysfix
download lynksys from main computer to portable flash and put it onto your lap top.
Dec 06, 2008 | Linksys Wireless-N WRT150N Router
WRT150N looses wireless connectivity
filasian, there is a strong possibility that the switch part of your router is defective because there is no light on number 2 even if there is a computer plugged into it, this can be the factor that affects the wireless operation of the unit.
the best move you may do at this point is to contact Linksys to perform a firmware flash on your router or discuss the warranty of the unit.
their toll free number is 1-800-326-7114
or refer to the site below to to see the contacts for linksys.
Linksys- Contact Us.
good luck
Jul 29, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
134 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
