Gateway 3200S. will not begin to power up. a green led is on at the top of the mainboard. that is the only indicator of power.
  • 43 Answers
Hi PLease try removing the Ram from from your machine and clean the surface and insert it back in case if it didn't work then you have to manually switch on the power button from the motherboard itself or check this link http://support.gateway.com/s/PC/3200Series/1008289/1008289nv.shtml
Posted on Jun 21, 2009
    Novelist:
  • 133 Answers
Dear Rythmickarma,
As you said the main power LED seems to be glowing but the system is not powering on... so there are few things to check here:
  1. Remove all other connections apart from Power supply, keyboard, mouse and monitor and see if that makes any difference.
  2. When the computer normally boots up there is a POST check Beep sound from CPU .. do you here any beep?
  3. When you tap on numlock key on your keyboard, do you see numlock LED toggle between ON and OFF state?
  4. Is there any signal on monitor .. When disconnected from the CPU, the monitor should show Self test signal .. does it happen?
  5. Open the chassis and check if you can feel the spinning of Hard drive...
  6. Remove the power supply cord from the back of the computer and press and hold the power button for few seconds .. this would drain the accumulated power from the CPU components .. now reconnect the power supply and see if that makes any difference..
Please try the above steps and let me know. Hope that helps.
Regards,
Srinivas
How to connect power led, power sw and hdd led on a gateway 3200S mother boad?
go to the motherboard manufacturers website and download the manual. In it there will be a picture of the motherboard connectors you are talking about then just connect them. The power switch connector can go either way as there is no polarity on it.
Jun 27, 2014 | Gateway Computers & Internet
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
The green led is lit, indicating power is on...but no picture
If you are sure all conections are ok, then your mainboard is damaged and will need to be replaced, I recommend you to try the TV with an external video source (like ipod or DVD).
Jul 03, 2009 | Toshiba 37AV500U 37 in. LCD TV
Gateway 3200S will not power up.
i have a big feeling its the mother board
Jun 04, 2009 | Computers & Internet
My desktop PC is a Gateway GT5656. The power
Could be try putting your power LED on your HDD LED header on your mainboard and then look at this while booting up and this will tell you if its the LED or the Header on your mainboard
May 03, 2009 | Gateway GT5654 Desktop PC
No power
Could be you power supply... try one from another machine.
Apr 04, 2009 | Gateway 3250S PC Desktop
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
My Gateway 3200S will not power on.
Check your power supply first.
Aug 12, 2008 | Computers & Internet
Computers & Internet Logo
235 people viewed this question
Alun Cox
David Payne
David Payne
