Question about Intel Motherboard
While Startup vhkdsk Runs But Stopped immediatly So Display This Words. "disk checking has been cancelled" What Can I Do?
    President:
  • 1,383 Answers
When you press power button press F8 key then enter in safe mdoe.
Tehn go to start menu then type in run "chkdsk /r"
then press "y"
then restart it then it fix error on harddisk pls dont touch any key while it fix error on disk
Posted on Jun 21, 2009
I have a samsung sens R20 laptop,when i boot it no display in monitor
REMOVE all media, DVDs/CDs, USBs...etc. Can you do a system restore/recovery by reboot , when the boot starts immediatly start tapping F-4 repeatly to load system restore/recovery.
Nov 12, 2012 | Computers & Internet
Asus K53E will only load Startup repair screen, run this but nothing happens
When startup repair finishes even if it says it could not fix the problem try rebooting and select to run windows if it gives you that option.
Maybe you need to run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 01, 2012 | ASUS Computer International K53e B1...
It's an IBM Thinkpad, I'm not sure on the year (if that even matters!) Ok, when I turn it on, this is what first pops up: We apologize for the inconvience, but Windows did not start successfully. A...
Your best and quickest way to fix your computer is to reinstall windows (same version that on computer) and use repair mode or use the install option
a repair disk Hirens boot CD is one of many
Feb 28, 2017 | IBM ThinkPad T21 2648 Notebook
Since Upgrading to tiger I have freezing,and startup problems,the display graphics aer wobbly with information missing
See if it will boot while holding down the shift key. This is a safe boot without any startup items and it automatically runs a disk repair.
Once booted open Disk Utility (found in application\utilities) and run Verify Disk to see if the repair was successful.
Aug 03, 2009 | Apple Mac Tiger 10.4
Chkdsk runs sporadically and never stops
Sometimes it happens that disk check always starts to check the file system on one or more drives for consistency. If any key is pressed, the disk checking is aborted. Actually this is because some data structure of the drive or some file is corrupted which can not be recovered and check disk is always run at Windows startup. Or sometimes it may take several hours for disk checking to scan all the drives. So disabling it or postponing disk check is better. There are several methods to disable disk checking at Windows startup. Two of them are given below:
Method 1: Using CHKNTFS utility CHKNTFS is a utility that has been developed by Microsoft to disable disk checking on certain drives at Windows startup. To use this utility go to Start –> Run –> cmd.
If you want to disable check disk on C: drive, use the following command on command prompt.
chkntfs /X C:
If you want to disable check disk on two or more drives, just keep on adding the drives:
chkntfs /X C: D: E:
This will disable check disk on C, D and E drives.
If you want to restore what you have done, that is, enable automatic disk checking on all the drives again, just run the following command:
chkntfs /D
This will restore all the drives to automatic disk checkup.
Method 2: Using Registry To disable automatic disk checking at Windows startup through registry, go to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager
In the right hand pane, double click BootExecute.
The default value of the key is autocheck autochk *
* means every drive is checked for consistency. Just add /K:C at the end before *. /K switch will disable autocheck on C: drive at Windows startup. So the final value should look like this:
autocheck autochk /k:C *
If you want to add more drives, the key should look like this: (disabling C and D drives)
autocheck autochk /k:C /k:D *
If you want to restore everything to default, just replace the key with the default one i.e.,
autocheck autochk *
Hope this will solve this issue.
Please rate your coments.. This will be helpfull to others.
Thanks & Regards
Nanda Kishore
Mar 31, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
No system found on hdd
Sounds like a HDD crash, try booting with a startup or recovery disk to see if you data is still there. If so, BACK UP IMMEDIATLY. Then you will have to reinstall your Operating System. MM85
Jul 22, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Gateway 7330GZ will not follow through at start up
At startup, hold down F8 key. select safe mode start. allow windows to guide you from there. if no-go, then repeat but choose dos prompt only, then insert a win 98 startup disk and run scan-disk on your drive. if no-go, in worst case, try to delete the pagefile.sys file from dos prompt (you may need to change file attributes from read-only and hidden and system to toggled-opposite-read, not hidden, not system). and repeat above steps
May 27, 2007 | Gateway 7330GZ (890552601318) PC Notebook
Intel Motherboard Logo
164 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
