Question about Intel Motherboard
Pls. Help! I can't figure out where to connect my power switch and other reset and led connector to my motherboard. The description found in my motherboard seems not clear. "4-6 Power switch", "+2-1 HD_Led", "+5-1 SUS_Led", "+3-1 Power_Led", nothing more. The pin arrangement look like this [::::.::] blank means w/o pin.
    President:
  • 1,383 Answers
1 -3 -5 -7 in upper and
2 -4 -6 -8 in lower line
then coonect as above
Posted on Jun 21, 2009
    Problem Solver:
  • 27 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
10
Posted on Aug 29, 2009
    Novelist:
  • 186 Answers
Where was your manual to tell you? If that is a hurdle for you, be careful.
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
Hello, I recently Bought a "Asus A8AE-LE Amberinem" motherboard, I just can't figure out which wires goes where and there's just too many, all that I found was this ->...
Each of the wires coming from the front-panel of your computer ends with a labelled connector:
* HDD LED
* POWER (PWR)
* POWER LED (PWR LED)
* RESET (RST)
* SPEAKER (SPKR)
Each group of gold-pins on the motherboard is similarly labelled.
All you _really_ need to connect is the POWER and RESET buttons,
but it's nice to connect the other ones, too.
Dec 23, 2010 | Computers & Internet
How to connect pwrswitch, pwrLED, IDE-LED, reset,
you will need a magnifying glass but theres a row of pins that are there to connect the power /all switches near one corner of the board and won;t have slots for all the lights you want to hook up ! just the function switches only!
Jan 13, 2010 | ASUS P5GC-MX/1333 Motherboard
http://www.motherboards.org/files/manuals/1/p4bmx-101.pdf
Here is the manual for this motherboard, and it shows you the pinout for the power switch, reset switch, power LED, HDD LED, and speaker.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Computers & Internet
Help!
Page 26 of the below PDF should have your answers.
http://www.globalamericaninc.com/manuals/2801550.pdf
It might also be in your manual just on a different page?
Jun 21, 2009 | Intel 865G Motherboard
CONNECTOR PROBLEM
Usually the connectors will be marked as in the picture, indicating their usage. 07471ce.jpgIf your connectors do not have a label printed on them you can figure out the important ones. You will have a pair of connectors each for the power switch, the reset switch, the power LED and the hard drive LED.
The two pairs of wires used for the switches are the important ones. They can be identified with a circuit tester or multimeter (Check for resistance/Ohms). When they are pressed, the meter should indicate a connection across the two wires. In the case of the power switch if it's a really old case it will toggle on and off, so watch for the continuity to change when you press it. Otherwise the reset and power switches will only register a connection when pressed, and revert to an open circuit when released. Use your multimeter to identify which pair reacts to which swtich, and label them with some masking tape and a sharpie (or equivalent way).
As long as you identify these two and connect them correctly you'll be okay. The LEDs are not essential to booting your system and you can figure them out later. LEDs have to be connected the correct way around (usually the white wire is negative), while the switches don't matter which way they are connected as long as it's to the correct two pins. You can connect the LEDs and see which ones light up on your panel to determine which is connected where. If your power-on LED lights when there's hard drive activity, then you know that the connector plugged into the pins for HDD LED is the wires for the power LED, and so forth.
Hope this helps.
Please rate my answer.
Jan 01, 2009 | Asrock P4i65GV Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
Intel Motherboard Logo
61 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
