Question about Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23
Lincoln Pro-mig 175 w/ no wire feed but relay clicks fan runs
Machine code 11009
*no voltage at wire feed motor
*relay clicks when trigger is pulled
*fan runs
It worked fine when I put it in storage for about 18 months. I finally got into a new shop and went to use the welder. Everything seemed fine untill I went to pull the triger and no wire feed...
I traced the wires from the feed motor to the circuit board and nothing looked suspicious. I'm guessing it's something with the integrated curcuit board. But it worked fine when I put it in storage...
  • Ned C Cook
    Ned C Cook May 11, 2010
    Are the drive spools turning?
  • bobby hughes
    bobby hughes Dec 06, 2017
    HAVING THE SAME PROBLEM ..DID YOU FIND PROBLEM,??. WHAT WAS THE FIX.. THKX
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with my MIG 175 Pro is the "voltage selector switch" (part # M15750-1). I took it apart and saw all of the contact points where corroded. I can hold the knob between two settings and the machine will work.
I have the same issue only after about a year of very light use. I am not sure how to prevent this from happening again.
Posted on Sep 04, 2009
  • NeonDion Apr 13, 2011
    My mig SP-135T had the similar problem with the Voltage Selector Switch. One of the contact points was totally gone. I recall it sticking and being hard - also after sitting in storage for several months.
    I ended up needing my welder BAD, so I jerry-rigged it. I took regular 110 house electrical wire (12 gauge), wrapped it around the contact point, (twice) and it left an even height on the Voltage Selector Switch. I did some testing at low voltages using .035 Flux wire and slowly worked my way up to max voltage. It worked fine and never even sparked once.
    So I closed up the cover and it awaits it's next welding project. I hope to replace the Voltage Selector Switch - if I can find the part. I did find a parts breakdown at searspartsdirect.com, search for model SP135T. Thanks and God Bless!
    Champion:
  • 225 Answers
Is the unit set for the right input voltage.
Posted on Jul 02, 2009
Our Lincoln Pro Mig 175 won't feed the wire. The trigger clicks and the motor works but will not feed the wire. There's a burnt resister or capacitor on the pc board and the only numbers that we...
Hi:
If your wire feed motor turns, then your problem is one of the two:
The gun's liner is kinked and no longer is allowing the wire to pass freely, or Your outlet wire guide/drive rolls are all worn out.
Easy fix will be to star with changing the liner and new contact tip. But if all that is working is your fan motor, then check your gun's trigger, if gun's trigger is OK, then change the pc board. Good luck!
Aug 29, 2011 | Lincoln Welding Tools
I have a brand new Lincoln pro mig 140. Took it out of the box and set it up yesterday. After approximately two hours of mild steel welding today the wire drive roller quit working. I've tested the...
I'm having a problem with the wire feed on my Lincoln Pro Mig 140. The wire feed speed is not consistant. It seems to be slipping even though the tension is tight. Any solutions?
Oct 18, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Jul 10, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
I have a sp 100 lincon pull the trigger it clicks, no wire fd
not diode problem,check enternal wiring and relay for feed motor.
Jun 25, 2009 | Lincoln Welding Tools
No wire feed
If the power to the unit/fan is on and the relay clicks the fuse is not the problem. Check your motor connections. Either you have a bad motor/wiring to motor or motor speed control board.
May 22, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23 Logo
2,552 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
