Samsung Bd-F5500 3D Network Blu-Ray And Dvd Player New For 2013 Logo
A
Anonymous Posted on Apr 28, 2014
How can i can it codefree? - Samsung Bd-F5500 3D Network Blu-Ray And Dvd Player New For 2013
Artie
Level 2:
Champion:
New Friend:
  • Expert 236 Answers
  • Posted on Nov 27, 2014
Artie
Expert
Level 2:
Champion:
New Friend:
Answers
236
Questions
0
Helped
56544
Points
309
Check videohelp.com.
How can I set my blu-ray player to codefree, please ?
Try the following:
Turn the player on and make sure that there is "no disc"
1. Press "OSD" on your remote
2. Press "3141590" the 0 is region 0 (region free)
Menu disappear and your player is now region free.
tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
1helpful
I bought this player (Coby DVD657) because it would play PAL format DVDs, but the region coding prevents this. Is there a way to reset the region code for this player to play Region 2 (or...
  1. Method 1:
  2. Press SETUP
  3. Press 2, 1, 8, 8
  4. A new menu entry appears (Version)
  5. Select it
  6. Press ENTER
  7. Select "Region" with RIGHT
  8. Select RC with UP, DOWN (0 = codefree)
  9. Press SETUP
  10. Turn the player off
  1. Method 2:
  2. Press SETUP
  3. Press VOL+, VOL-, VOL+, VOL-
  4. Current RC should be displayed
  5. Select the RC with RIGHT and LEFT (255=Codefree)
  6. Press SETUP
  7. Turn the player off
How can I find/reset passwords on Coby 224S and Coby 206
http://www.dvddemystifiziert.de/codefree_en/coby.html
Unfortunately, I don't see Coby 206. There is a 207 however if that would work.
Unlock Coby DVD players - DVD hack
Coby DVD-201 / DVD-217 / DVD-224 / DVD-227 / DVD-237 / DVD-505 / DVD-514 / DVD-527
  1. Press SETUP
  2. Press VOL+, VOL-, VOL+, VOL-
  3. Current RC should be displayed
  4. Select the RC with RIGHT and LEFT (255=Codefree)
  5. Press SETUP
  6. Turn the player off
Coby DVD-202 / DVD-203 / DVD-207 / DVD-208 / DVD-218 / DVD-507 / DVD-508 / DVD-606 / DVD-615
  1. Method 1:
  2. Press SETUP
  3. Press 2, 1, 8, 8
  5. Select it
  6. Press ENTER
  9. Press SETUP
  1. Method 2:
  2. Press SETUP
  6. Press SETUP
Region Unlock Code
Go to http;//www.dvdcity.com/codefree/instructions.html maybe there you find an answer.good luck
Unlocking regional code
Go to http;//www.dvdcity.com/codefree/instructions.html .Good luck
Unlock region code
Go to http;//www.dvdcity.com/codefree/instructions.html maybe there you find the answer.Good luck
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
7helpful
2answers
GO VIDEO DVD + VCR model: DV 1130 I want only the basic connection
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
