Question about Phoenix Gold Octane-R 4.0:2 Car Audio Amplifier
Want to know how many watts a Phoenix gold R 4.0:2 is
    President:
  • Phoenix Gold Master
  • 1,114 Answers
It's "Clean" power is 75 x 2 at 4ohms
and 125 x 2 at 2ohms
Bridged mono it's 300 clean.
Posted on Jun 21, 2009
How many watts in a Phoenix Gold XS 4300
XS4300 SPECIFICATIONS:
Output Power: 4 ohm stereo @ 12/13.8 VDC 12/35 WRMS x 4 2 ohm stereo @ 13.8 VDC 75 WRMS x 4 4 ohm bridged @ 13.8 VDC 150 WRMS x 2 Crossover Frequencies 20Hz to 20kHz(Rnet factory set at 100Hz) Crossover Slopes 24dB per Octave
Jan 14, 2015 | Phoenix Gold Car Audio & Video
I have a phoenix gold Qx 180.2 amp and im gonna push two 10" comp kicker subwoofers. will it work
Do you no the continus whate rateing of it? End i don,t mean peak or maximiun Watts on it, All so the RMS) watts that the sub will handle,
Nov 12, 2012 | Phoenix Gold QX 180.2 Car Audio Amplifier
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
How many watts is a white phoenix gold ms 2125 triple darlingtion high definition amplifire
into 4 ohm 13.8 volts 160 watts rms x2 2 ohm 13.8 volts 255 watts rms x2bridged 4 ohm 13.8 volts 510 rms
hope that helps or follow link to manual
http://download.phoenixphorum.com/Manuals/Amplifiers/MS_MAC_Amps/ms2125.pdf
Aug 15, 2010 | Phoenix Gold Limited Edition MS2125 TA...
Does any body know many watts is a Phoenix Gold QX2180?
Normally the numbers give you a big hint. 2180 means this is a 2 CHANNEL AMP EACH CHANNEL CAN PRODUCE 180 WATTS OR 360 WATTS BRIDGED.
Apr 05, 2010 | Phoenix Gold QX2180 Car Audio Amplifier
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
How to hook up led lights for phoenix gold x10d4 speakers
THERE ARE 2 WAYS:
1. (STEADY ON) - RUN THE POWER FROM THE AMP TO THE POSITIVE LED TERMINAL THE NEGATIVE CAN BE RAN FROM THE NEGATIVE SPEAKER TERMINAL.
2. (INTERMITTENT; COMES ONE EVERY TIME THE BASS HITS) - RUN THE POSITIVE AND NEGATIVE WIRES FROM THE + AND - TERMINALS TO THE POSITIVE AND NEGATIVE TERMINALS OF THE LED LIGHTS.
LET ME KNOW IF THIS WORKS FOR YOU -- CADILAC00@HOTMAIL.COM
Mar 15, 2009 | Phoenix Gold Xenon X10D4 - 10" D4...
Interference
how many watts is the amp and speker are you sure you are not putting too much?
Jan 31, 2008 | Phoenix Gold Ti600.2 Car Audio Amplifier
Phoenix Gold Octane-R 4.0:2 Car Audio Amplifier Logo
153 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
