This might be a case of pump was not stored correctly from 1st season , now pump shaft has become dry and tight , well if your handy with a phillips head you could try and dissasembe pump and lube shaft with waterproof grease ( kitchen faucet parts in hardware store)
i allways store my pump filled with food grade antifreeze (rv grade) and hoses capped off and pointed up , it stays all winter inside an unheated shed with no problems for two swiming seasons now
SOURCE: intex sand filter motor will not run
Opening the little drain plug at the bottom should relieve the pressure and make it easier to turn the basket lid. Is there water to the top of the basket? I had to loosen the clear top of the basket to bleed the air out. If you open the drain where you backwash, will water flow out? It should. Mine flowed out even without the motor running if I remember correctly. If it does not, my guess would be some kind of obstruction.
Increase Engine Horsepower.
Testimonial: "Thank you, found hair in impellar once I cleaned it out worked perfectlty"
