Showing doubles (red)
My television just started showing doubles and a haze. The double part is in red. Could this be the picture tube?
  • 2 more comments
  • Maryw Nov 06, 2007
    I haved aHitachi Projection Color TV Modle 46F500 when there are words on the screen they are double and the top of screnn has a wave with a color distrortion A person face is lioke having double vision. I have tried magic focus and I have tried to adjust the Convergence. Nothening has worked.
    Thank You
    Mary Wilkinson
  • Anonymous Nov 20, 2007
    found on your site that i am dealing with conversion mis-alignment ,I ve tried focus on tubes and in front,adjusted color, How do you adjust conversion mis-alignment??? peter
  • vernell1 Nov 25, 2007
    my color is showing red blue and green on thepicture and have a wave to the top and botter.
  • osmo Dec 23, 2007
    red horizon mis-alignment
  • 1,694 Answers
Not the red CRT-----problem is called convergence mis-alignment.
Please provide make,model and age for accurate repair details.
Posted on Nov 03, 2007
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
How do i find out if sony kp/57ws510 picture tube is bad
While the set is prone to bad tubes a double or 3d like image is convergence--this model uses two of the STK-392-560 CHIPS for this.
Go into customer menu and call up convergence--if off and will not adjust in any area of the screen the chips are bad.
May 02, 2012 | Sony KP-57WS510 57" Rear Projection HDTV
I have a phillips 55pw9363 my picture is hazy. It does not change when I adjust the brightness.
Tv pictures and screen brightness are dulls and have a halo glow to it wright?Yes.The tv CRTS TUBES guns have a chemical call CRTS TUBES coolants are contaminated require changing.Tries websites like, to buy a chemical coolant kit to replace it.Kit also came with a tutoring DVD disc showing u how to replace the CRTS TUBES guns coolant chemical.
Apr 03, 2011 | Philips 55PW9363 55" Rear Projection...
Double picture...not focusing right
maybe parts inside is worn out. causing the blurrines. just consult to your service center.
Jun 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
TV has red lines and showing double the picture. One Sears tech suggested may have to replace bulb for $500???
yes thats a good price to replace a bad red picture tube and at the same time the convergence ic , this is for the doble picture and lines
Apr 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Sony KP 48S75 Rear Projection Red Haze around objects on screen
Sometimes this can be caused by excessive dust buildup on the lens over the red picture tube, and if you have access to that part of the set, that is where I would start. If it is clean, then you could have the red tube out of focus either due to a bad focus block or if you were lucky, a minor adjustment may fix it. If the set was over 8 years old, I'd consider replacing it with a HDTV model. Check out Consumer Reports latest issue for a start.
Dec 16, 2006 | Sony KP48V85GRAY 48" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
