Question about Tomtom ONE GPS Receiver
Power pin broken off inside tomtom 910 - Tomtom ONE GPS Receiver
    Problem Solver:
  • 6 Answers
Return to the point of purchase and request that the untit be returned to the Authorised Repairer to have the broken part replaced.
Warm Regards
Bill Held
Posted on Jun 21, 2009
  • 502 Answers
If you're comfortable with taking apart devices you can try a gps repair website that shows you how to replace the logic board or power jack yourself.
Posted on Jun 24, 2009
Computor does not reconise my tomtom go 910 satnav says formatting failed computor says usb device has failed
Power on the TT 910 and then press the Reset Button on the base of the TT. It is a tiny hole with a hidden button. use a rounded object, match end or soft pencil to puch the button. Then reconnect it to the PC and the PC will see the TT. Note that you may have to reload apps and maps depending on the state of the TT.
Nov 13, 2009 | Tomtom GO 910
Tomtom go 910 power connecter
Yes Chris it can be repaired. I do it all the time. The culprit is usually the negative pin. The negative pin is the gold pin on the far right hand side. With the unit upside down (you can see the contact pins on the board) and the lcd faceing you the negative pin will be on your far right hand side just below the reset hole. Doing it and telling you how to do it are two different matters.
Oct 15, 2009 | Tomtom GO 910 GPS Receiver
Tomtom 910 power problem
It is very small - a pinhole. Use a paperclip to press the button which is sunk inside the small hole.
Jun 27, 2009 | Tomtom GO 910
Power to same, but not turning on, can't locate so-called
look at the base of your unit with the screen facing away from you, just in front off the rubber bung is flat piece of plastic with a tiny curved out cection on the left hand side, below there is a tiny hole just big enough to poke a pin in their.
May 30, 2009 | Tomtom GO 910
Specs GPS GO 910 Tomtom
yes it should come with a universal voltage adapter and eu two pin connector.
Apr 11, 2009 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 910
Check your battery symbol.
On mine, the battery is dead (or mechanically disconneced inside).
You need to reset the unit by pressing the tiny button on the back.
Problem is that when you remove the unit from the charging stand, the dead battery does not allow you to press the reset button. (Pressing the reset button with no battery cannot reset the unit)
IF you could press the reset button while plugged into the charger, you could get you unit working again. But..alas, the design of the unit prohibits you from doing so.
Chances are if you fix the battery problem, you will have a usable unit again.
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Tom tom Go 910 won't turn on
Suggestion
Charge the tomtom over night,
Reset
And before you switch on connective to the PC and run the updates via you Supplied CD Software.
Jul 26, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910
Unfortunately, when it comes to the PIN codes, if you do not remember the code, there is little that can be done. Usually you must enter the correct code, go to where it was set, or return the unit to the manufacturer.
Feb 18, 2008 | Tomtom GO 910 GPS Receiver
Faulty tomtom go 910
have to send it in to get battery replaced.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
TomTom will not switch on even when it is plugged into the mains power
yes just press the reset button under the tomtom you can find this next to all the pins where your tomtom dock goes in.
Dec 17, 2007 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
390 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
