Question about Amana Refrigerators
Freezer not freezing
I have an Amana refrigerator model # ATB1935HR which is not cooling properly. The fan kicks on amd the compressor is running but the cold tube comming out of the compressor is only mildly cool. Things in the freezer are slowly thawing.
I would add a small detail. For a few weeks I have noticed a short buzzing noise that seems to be comming from the back of the machine. It is something clicking on, it makes a kind of 60 Hz buzz for maybe three seconds then snaps off, not loud, but noticable. I don't know if that is relavent. Could it be stuck in defrost mode? If so, What do I do? This frig is less than three years old and so far, has been flawless.
  • 2 more comments
  • jaxmaylbox Jun 21, 2009
    I have not heard the buzz for a while, the link you sent does not look like my refigerator. I don't know exactly how to check the starter or overload relay, but it does (or did) sound like a relay switch or overload. I don't know how to check the thermostat or the freon and all of the exposed wires look brand new. The thermostat link looked like a themostat from a car. I know it's hard to diagnose from afar but I do need some help. As far as I can tell, the buzz has gone, but the refigerator is just not getting cold, it's just getting cool.
    Nicolocarlo,
    Thanks by the way for your quick replies. I forgot to say that I did clean out the coils. I will check the things you recommended and get back I'm just not sure right now when I can. Is there any specific reason I would loose the coolant? If so, how do I replace it?
  • jaxmaylbox Jun 22, 2009
    VOTIT,
    Hey, and thanks for your suggestion. I have emptied the refigerator and taken the back out of the freezer compartment. The evapotrator fan is working just fine, the coils are free of ice and the drain tube is also clear. I did find however a component that was frozen over with about a four inch by two inch block of ice. I cannot tell what the component is but the ice is covering the in-bound and the out-bound tube for the coolant as well as what looks to be a bi-metal thermostat wire. Could this be the "termistor" you referred to? It is located near the evaporator fan and just behind the light fixture in the freezer (high and at the top right of the compartment). I'm going to thaw it out and restart the unit to see if the problem is solved. Thanks again. Jack.
    PS Could this situation have arisen if there were frozen items partially blocking the fan opening?
  • jaxmaylbox Jun 23, 2009
    m0bum,
    Thanks for the info. I have completely defrosted the refigierator and turned it back on. Everything seems to be working fine except the machine cooled down to 40 degrees F in the freezer compartment and it seems to be stuck at this temperature. Does this mean it is stuck in defrost mode? Or is it something else? Thanks
  • 351 Answers
I would recommend you stop waisting your money and give me a call 866-798-4375 Mark and i will assist you for free... whirlpoolpartssurplus.com
Posted on Jun 23, 2009
    Scholar:
  • 94 Answers
Make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
  • 2,071 Answers
Your freezer does not work properly it is often the thermostat starting the cooling process that is faulty.Try first to defrost completely, to see if this unjam the thermic sensor, if it does not work you will need to replace the thermistor.Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change first thermostat , then check fan motor. Also check the water hole drainage for clogged up from the freezer down to motor where the water exit located.
Just click below;
It's not cool
Cooling is poor
It's noisy
The freezer compartment is icing
Hope it may helps:
Regards:
VOTIT
Posted on Jun 22, 2009
    President:
  • 2,187 Answers
The buzzing sound may or may not be related to the cooling power of your refrigerator. There are 2 things where the sound may originate from. One is the mechanical component, which is your compressor or the electrical components. You have to go back and listen to it carefully. For the electrical components it may probably be the starter or overload relay. Below is a link to show its location.
Relay
If they check out OK you may want to look at the wiring if there wires exposed. If the buzzing is fixed and the refrigerator still acts the same, you may want to check on the thermostat and the freon.
Posted on Jun 21, 2009
  • Nicolo Carlo Parazo Jun 21, 2009
    the refrigerator may be different but from the back all of them has almost the same components. The box that contain relays may look different and located differently.
    You can also try to clan out the coils at the back see if it will help. The defrost switch/timer/thermostat may have gone bad. In you manual it may refer to it as either of the 3. It should be the only electrical component linked to the inside aside from the light and the switch. It is usually located where you have the fans. I am having a hard time getting a picture of the unit I have from the web but the link below should be close.
    Defrost/Thermostat
    Below is a link on how to test it.
    Defrost Timer
    I hope it works. If it all checks out after cleaning the coils and the above steps, you will have to check the freon if you have the correct amount. You will have to need a special to measure this one.
  • Nicolo Carlo Parazo Jun 22, 2009
    I would suggest to start first with checking with the thermostat before the coolant/freon in the post before this, since this is most common with all refrigerators. Normally if there are leaks or loose linkages in your pipes, this may happen. If all check out OK have the compressor checked out if it has weakened.
    Thank you
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
Water is dripping on the top shelf from above
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Amana ATB1935HR Top Freezer Refrigerator
Freezer is frosting up and refrigerator is not cold.
heatman101
Dec 08, 2010 | Amana ATB1935HR Top Freezer Refrigerator
Fan is blowing but the cold air in freezer is not cold enough to freeze food. Temp control has been turned up to max setting.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Nov 20, 2010 | Amana ATB1935HR Top Freezer Refrigerator
I have an Amana bottom freezer refrigerator, model no. BX21V1C,it stopped cooling and freezing. The relay was replaced 6 months ago and now it has happened again. You can hear the click and buzz of the...
Good day,
Sounds as if the relay has failed again. ....or when relays start going bad, it could be an issue with the internal part of the compressor.
But the relay approach should be your first step.
Thank you for using FixYa
Jan 26, 2010 | Amana ABB1927DE Bottom Freezer...
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Amana refrigerators is not staying cold and freezer is not freezing. Makes a "humming" sound, on and off, like a low "grind" noise, or like the noise an airconditioner makes prior to kicking on.
Mine had the same problem, and I had a tech out today who determined it's the motor inside the freezer. It's (the fan) not running. It's a $100 part, but if your refrigerator is new enough, it's probably worth the investment to go ahead and have it fixed.
Jul 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Double Door refrigerator not freezing in the freezer side.
sounds like a leak ,as long as the compressor fan is running it is a leak. it can be fixed by a technician only due to the tools needed for the repair. these tools cost well over 1000usd and may not be worth purchasing for a single repair.
Phil
Jun 10, 2009 | Refrigerators
Amana Side by Side No Power
Do you know if you have a mechanical defrost. On the older side by side Amanda's there is the defrost control timer at the bottom in front. Put a screw driver in the slot and advance the timer. If it is stuck everything will be off. Think it's a small red dial. Open both doors, take off the front kick plate and it is under the front.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
Jan 20, 2018 | Amana ATB1935HR Top Freezer Refrigerator
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not...
hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Sep 26, 2008 | Refrigerators
Refrigerators Logo
157 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
