Question about Kitchen Ranges
Heating problem with Whirlpool Oven RS6755XYN
Digital front panel display says it is at temp, but food id not cooking right. for instance, pizza cooks on top, but crust is mushy. idea's? power is correct.
  • 878 Answers
SOURCE: oven is cooking unevenly
ladder, here are some suggestions to try to help you with this problem. Make sure that you wait another 10 minutes to put your food in after the preheat light goes out or tone goes on. The manufactures like to get that energy effecient label on these ranges. If your utensil is dark, darkened by age or glass, these will absorb more heat and can cause over browning. Lower the oven temp for these types of utensils or use a pan with a shiney finish. Make sure the utensil is not too close to any oven wall. Do not check for doneness until minimum recommended baking time. Opening the door frequently causes the lower element to cycle and provides too much intense heat. Use the second or third rack from the bottom. Finally, check the owners manual for calibration instructions. You might be off with that. back.
Posted on Dec 18, 2006
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
  • 146 Answers
SOURCE: Gas oven not heating to temp
You more than likely have a defective oven sensor. For some reason the sensors tend to go after a few years of use. It is in the upper right or left hand corner and looks like a probe sticking through the inside back of the range. When you open the door you just look towards the top back left or right corner there are 2 screw securing it to the back. Gently pull it forward. You will see a couple of small wires feed into as you pull it in. On most you will see a plug in connector come through the hole if not you may have to just splice the new one in.
Posted on Dec 21, 2007
  • 210 Answers
SOURCE: display
This is an error code, the error E1-F1 indicates that the Electronic Range Control/Clock has been blown. You have to get it replaced.
Sgt 48
Posted on Jun 04, 2008
  • 525 Answers
SOURCE: maytag advanced cooking system
I attempted to locate a user's manual for you but your model number came back as invalid, please recheck your model number, and follow the link that I provided. This will allow you to download a manual for your range.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 18, 2008
  • 187 Answers
SOURCE: Whirlpool gas oven won't heat to proper temp.
The oven has a temperature sensor inside. The sensor tells the oven when to go on and off. It may need replacement. The sensor is protrudes from the back left wall of the inside of the oven. Make sure that it is fully plugged in and that it is not covered with any goop from the oven. The other things you can check is that nothing is obstruction the heat. That means NO foil or coverings on the bottom of the oven. It blocks the heat vents and can damage your oven. Underneath the floor of you oven, you will find the gas jets.The flame should come out blue and steady. It it is sputtering and orange, the little holes might be blocked. Clean carefully.
Posted on Nov 15, 2009
Testimonial: "Thank you for your input. It was very helpful. Unfort. we had to replace the entire oven due to several problems."
0 characters
1 Points
My Maytag convection oven has the heating elements on the top. It doesn't matter if I use convection or not, metal, nonstick, or stone pans, or lower the temperature or cooking time, it doesn't cook/bake...
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?
You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.
Your oven sensor or thermostat might be at fault.
Oct 20, 2013 | Maytag MGR5770 Gas Kitchen Range
The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thanks for using fixya
Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
My oven heats up but will not heat up enouph to cook food fully. If i bake a pizza it never gets done enouph and cakes...etc
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
May 07, 2010 | Maytag MER5530 Electric Kitchen Range
Whirlpool gas oven shuts down after cooking for extended periods
id like to see it happen bfore replacin parts, but the control panel is the only "control for bake" there is no "resetable thermostat", and it uses direct spark , not an ignitor( usual suspect)..perhaps after long heating the relay on the control heats up and doesnt close correctly
Jan 20, 2009 | Whirlpool SF367 Gas Kitchen Range
Oven won't work
just go ahead and change to glow ignitor it is between 40 and 80 bucks
Dec 30, 2008 | Kitchen Ranges
Oven consistently burns food no matter what temperature setting
Well, must confess, we had this problem once, after cleaning all the knobs. We put them back, reversing the two temp knobs. The correct placement, we found, was the left oven knob, since it is not self cleaning, does not have the word CLEAN. This is the far left knob. Next, from left to right, appearing very simmilar, also with temps 200 to 500, is the right oven temp knob, which does say CLEAN. Third from left is the right oven function knob, with CLEAN, Time Cook, etc, and no temp numbers. Hope your fix is this simple. Hope your cooking is looking good cooking.
Dec 07, 2008 | Jenn-Air Kitchen Ranges
GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Not cooking completely
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Jan 25, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
