Question about Sunrise Medical Guardian Trek 4
Scooter just stops
When I am trying to get around sometimes the scooter will just stop & make a loud beeping noise. I have to turn it off & wait a few seconds to power back up & get the scooter to move. Very frustrating! Can't figure out why this happens.
    Problem Solver:
  • 9 Answers
Battery connection problems cause the controller to overheat. Once you have allowed the electronics to cool down, all seems well again. Get on your knees and check that the battery terminals are secured very well. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
Pride gogo sport motor just quit while going along a sidewalk.
Hi it's possible the control box down timer was activated check if freewheel lever is in drive remove key & wait a few minutes replace key & turn on cheers.
Nov 09, 2017 | Pride Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
sounds like hard drive is bad, replace with new or buy new computer
Jan 09, 2013 | Acer Aspire Computers & Internet
Beeping noise interior 2001escape
Same as the Ford Ranger. The Airbag Interlock for turning the Passenger side air bag off has a burned out light. You can dismantle this unit and replace the light with one from ford but it has to be soldered in place.
Oct 21, 2012 | 2001 Ford Escape
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Mar 07, 2010 | Health & Beauty
Computer start up issue. Very loud noise. Restarts by itself.
It can also beep an error code.
Like 2 short beeps and no video - memory problem.....etc.
Mar 20, 2009 | E-Machines T6524 PC Desktop
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My samsung L730 lense is stuck
i have the same problem with these camera. to get it fixed just take out the battery wait for a few sec and put the battery back on, then switch the camera on. for the lens just gently move/force the lens to open, then turn off the camera wait for a few seconds then turn on the camera back on see what happens. and if still persist keep doing it till gets back to normal.
this sometimes happens to my camera from time to time i think it just its wear and tear.
one more problem with this camera is that it'll go blurr, just do the basic turn off or take out the battery wait a few sec and then turn it back on.
hope this will help u.
Nov 08, 2008 | Samsung Digimax L730 Digital Camera
Sunrise Medical Guardian Trek 4 Logo
295 people viewed this question
Top Sunrise Medical Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Sunrise Medical Health and Beauty Expert? Answer questions, earn points and help others
