Question about Toshiba Televison & Video
Can't receive digital channels off air anymore.
Have Toshiba projection tv, Model 56MX195, with built in digital converter. Had been able to get several digital channels off the air BEFORE the big change this month. Now we can only get 2 channels. We have roof top antenna that also supports 2 other tv's. They receive all digital channels. We have rescanned several times, reset, unplugged, you name it. Do we need to get some other converter for it?,
  • Brett Duxbury
    Brett Duxbury Aug 04, 2017
    Hi annettek79, It could be the type of digital encoding the tv station is using ? We has issues with a horse racing channel that had a lower grade of encoding check if it is mpeg -2 or mpeg -4 for the tv station involved. Then check if tv can handle the encoding used . http://www.acma.gov.au/theACMA/engage-bl...
4 Suggested Answers
  • 927 Answers
SOURCE: digital tv
Good Day, tuff65;
Today with "HD TV" get a good UHF/HD antenna. You can get at any local Best Buy, Circuit City, Radio Shack etc.
Good Luck, big IRISH. PS: Inside or outdoors.
Posted on Sep 08, 2008
  • 5 Answers
SOURCE: hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
Posted on Aug 29, 2009
SOURCE: need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
Posted on Feb 14, 2010
Toshiba 32hl67us -- I am attaching an indoor antenna to receive digital local channels, the tv will only search in analog.. Do I need a converter?
You don't need a converter. You would need one if you had an older Analog TV, to enable it to receive Digital over the air channels.
Check the manual to read about the various configuration sub menus. My TV is a Samsung and when I want to scan for channels, I can select AIR, CABLE, or AUTO. After I select AIR it goes on checking the spectrum, looking for DTVair and Air.
Nov 05, 2013 | Televison & Video
Digital channels antenna
If you have a HD TV then you do not need a converter box, however you will still need an antennae to receive the channels. the antennae can be hooked up directly to you're HD tv.
Oct 27, 2013 | Toshiba 46H84 46" Rear Projection...
I was watching my Toshiba 56mx195 DLP tv and heard a popping noise and the screen went blank but the sound was still on, is it the lamp or something worse?
You are correct in this assumption it is more than likely the lamp that blew after too many hours or getting to hot.
Apr 21, 2013 | Toshiba 56MX195 56" SDTV
Toshiba 56mx195 tv will not turn on without lamp cover door
First, you need to fix the power supply problem, then take care of the door
Oct 11, 2012 | Toshiba 56MX195 56" SDTV
With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
I bought a toshiba 36HF12 36" tv
The TV does need a converter box to receive digital off-the-air broadcasts. It's an HD set, but that doesn't mean digital; no digital tuner was built in. You can find the manual here at Toshiba. Hope this helps, and thanks for using Fixya!
Feb 18, 2010 | Toshiba 36HF12 TV
Model 55311 Can you pick up digital tv without converter box?
I am thinking that you have a Mitsubishi WS-55311. If this is the case, you will need a converter box to receive digital television signals.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
Sep 20, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Digital Channels??
Direct from the Hitachi website - "Integrated HDTV Tuners: Hitachi's new top-of-the-line XWX series features built-in ATSC terrestrial and cable HDTV tuners to provide integrated high resolution, high-definition signal decoding." You will need a seperate HDTV tuner if you do not have cable or satellite and want to watch off-air High Definition channels.
Apr 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Televison & Video Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
