Question about LG Washing Machines
Power problem Hi Guys every time i turn power on at wall , switch on machine it trips the safety switch in power box instantly every time can you give me an idea on what could be the problem Regards Robert
    President:
  • 632 Answers
Your machine has a short circuit in it especially if it's not electronic..Most likely the motor windings..you have to pull out the motor and perform necessary tests..you need the technical know-how to do it..
Posted on Jun 21, 2009
My fisher and payment washing machine takes out the power to the house when we turn it on at the power unit
Hi, this sound like a serious fault that is tripping house rcd.
(a safety device that detects imballence between live/netural/earth)
So, UNPLUG THE MACHINE, TO STOP YOU GETTING A SHOCK ,AS IT WILL HURT YOU WHILST ITKILLS YOU, look inside for burnt cables, damaged wires, water leaks onto/over ANY THING THAT SHOULD BE DRY.
Is it tripping instantly at turn on, or at the same point along in cycle, ie pump running to empty machine, that will narrow down the area to look at.
BE CAREFUL THOUGH, AS WATER, ELECTRICITY AND HUMANS DO NOT MIX WELL.....
Nov 30, 2017 | Fisher Washing Machines
Hi their, I'm having problems turning the washing machine on it finished a load then wouldn't turn on again think yous can help me with that one
Hi. Make sure it's still plugged in. If it is then check the fuse box to ensure the breaker hasn't been tripped. If it has been tripped you could try just turning it OFF and the ON but there may be something wrong with your machine if this is the case and I wouldn't use it again until whatever tripped it was fixed. Another thing that might cause it to not run is the door may not be seating properly. There's a safety switch in most washers that will keep it from running if not activated. Call the manufacturer or visit their website and see if there's a solution there.
Good luck
Aug 09, 2016 | Washing Machines
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
May 17, 2012 | Washing Machines
Went to switch oven on fan works when you turn the temp knob it trips the trip switch every time help
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | AEG B3101-4 Electric Single Oven
My LG WD-1049C has suddenly starting causing our power to go out and the safety switch flicks on/off. Doesn't appear to be any water leaking out. No error message displayed.
Hi just read your posting.Does your machine trip the power as soon as it is turned on or after it has been on for a time?Usually on the front loaders it is the heating element that trips the safety switch.Have you tried setting the wash temp to a cold wash?Please reply with additional information and I will help you as much as I can.Looking forward to your reply.
Sep 18, 2010 | LG WM-12230FB Front Load Washer
The dishwasher trips the safety switch in the meterbox. whirlpool ADP 5000 made in germany (not on the drop down list) the 1st time was after a finished cycle and the power was off in the morning. the...
Please DO NOT touch this machine IF the power is ON. There is a possibility of shock. The reason, the ONLY reason, that the Breaker "Trips" is, if there is a, Phase fault to Earth/Neutral, in other words the CASE of the machine. Please get a serviceman or electrician.
Feb 04, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Moved Kenmore dishwasher to new house. Installed it. It will not start. Is there a reset switch? Model 587-1541590. Electrical installation checked OK. Water connection checked OK. Is there something I...
You say "electrical installation checked OK"...is the machine hard wired into a junction box or does it plug into an outlet?
If in a wall socket the new house circut may be on a wall switch which is currently off. If it is plugged into a GFI outlet it may have tripped, Find another power source to wire to, GFI plugs and dishmachines just don't get along, Learned that some time ago!
There may be an issue with your door safety switch on the unit.
Check for voltage where the house wires are wire capped in the machine if hard wired, sometimes twisting those can cause issues.
I doubt your machine has a reset switch but many hobart units have on on the motors.
It really sounds like you have a voltage issue.
Dec 22, 2009 | Kenmore Dishwashers
Hi had trouble with water tap feeding dishwasher , was leaking
it trips the safety switch because the machine is unsafe
call an electrician to do an insulation check , wiring and component check
Nov 18, 2017 | Siemens 24 in. SE25A091 Hi-Line...
Washing Machines Logo
52 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
