Question about E-Machines (T2824) PC Desktop
Cpu doesnt work
The cpu of my computer doesnt work. i connect it with power and all the connectons are correct but it still doesnt work. what is the solutions????
  • zalrashdi20 Jun 21, 2009
    thanks alot for responding my application. i will be in contact with you if i have a problem.
    thank you again
    Novelist:
  • 133 Answers
Dear Zalrashdi20,
When you say that the CPU doesn't work, what happens exactly? Does it not power on OR There are beep sounds heard OR there is an error on screen that you would like to share? OR ...
Assuming that the machine is not powering on at all .. here are few checks that you would like to perform...
  1. There is a toggle switch (Voltage selector) at the back of the computer on the power supply unit, just besides where you connect the power cable .. make sure that appropriate voltage is selected.
  2. Try connecting the computer to a different wall socket.
  3. If computer is connected through the Surge protector or UPS then try connecting it directly to the wall socket.
  4. Try using a spare power cable if available.
  5. Remove all other connections apart from Power supply, keyboard, mouse and monitor and see if that makes any difference.
  6. Remove the power supply cord from the back of the computer and press and hold the power button for few seconds .. this would drain the accumulated power from the CPU components .. now reconnect the power supply and see if that makes any difference..
  7. Open the chassis and see that couple of wires run from behind the power button on the CPU to the big circuit board (Motherboard) .. make sure that the wires are properly secured.
Perform these basic checks and let me know and I would glad to assist you further.
Regards,
Srinivas
Posted on Jun 21, 2009
Ive got a msi 785G-E53 Mobo whenever i plug in the pwr1,en-10 on my mother board it doesnt work help please
What i found there is two point to plug in to the motherboard. one is the power the second runs the power button the second one on mine is a six pin cable.
Aug 04, 2016 | MSI Computers & Internet
No Display on boot up
When a motherboard does not beep that isnt good news and its either the Motherboard or CPU. Have you fot the FSB settings correct on the board? Is your power Supply Good? Does your graphics card need power and is it plugged in? Unfortunately the only way to findout exactly is at fault is through a process of elimination. Can you try a different power supply first? Also try removing the CPU and re-seating it. If not, then you need to try and get hold of another motherboard and see if everything works in that. If not then it could be the CPU. Diagnosing CPU or MOTHERBOARD is always tricky without spares. Good luck
Aug 30, 2007 | ASUS P5NSLI (0610839134670) Motherboard
Hi i have a P4M800P7MA-ERS2H foxconn M/B that powers up but nothingelse -doesnt boot how can i tell if its a cpu or motherboard fault ty warren
Normally the only way to be sure is to use a CPU that you know works in another computer and test it in the motherboard that is not working. Also make sure that everything is connected to the motherboard properly and you can try disconnecting everything except CPU, RAM, video, and power to see if the computer boots like that.
Feb 17, 2012 | Foxconn 650M02-G-6L Motherboard
No power
If you are not getting the power then first of al;l check the power connecter on the back of the cpu fix it if lose.Then also you are geeting this problem then open the cabinet and fix the fan.Below is the relative figure07682fa.jpg
This will solve your problem
thanks have a great day
please rate me for this if it works
Jun 22, 2010 | Computers & Internet
Have a p4 machine doesnt power on when the cpu power connector is connected
this problem is always associated with power pack, i will advice you change the power pack.
May 19, 2010 | Intel Computers: P4 3.0GHz Mid Tower...
COMPUTER WON'T EVEN BOOT UP
PLEASE READ TO END BEFORE TRYING!!!
Did you try the simple fix? First thing is to unplug the computer and then push the power button. Plug the computer back in and then hit the power button again. Did it start? Hopefully. If not and its a desktop, take the side cover off and look at the mainboard. Are the capacitors all flat on top? If any of the capacitors are bulging on top your mainboard is probably going to need to be replace. If not, pull the power connector off of the mainboard. Now take a technicians secret tool (paper clip) and bend it around in a loop and connect the green and one black wire from that connector. This will automatically turn the power supply on if its not defective. This is the simplest of tests for the power supply and will not tell you if you are getting the correct voltages but it will at least let you know if it works at all. Sometimes the fan will come on but the fan will turn slower than usual. This indicates a bad power supply as well. If the power supply is not the problem, plug the power supply back in and unplug all the drives from the mainboard. Now try to power up the computer. If it still doesnt start, remove your RAM and try to power up. If that doesnt work remove all the plug in cards. Try to power up again. If that doesnt work then its probably the Mainboard or CPU.
Hope this helps. If it does please rate it. Thanks...
Sep 24, 2009 | HP Computers & Internet
Materbord probalam
If it doesnt switch on make sure all the power supply connectors are connected to the motherboard.
Make sure the power switch lead is connected correctly to the power on pins on the board too.
Make sure the CPU fan is connected to the Fan connector on the motherboard to see if the fan spins or not.
Try a more powerfull power supply 400w or higher.
May 14, 2009 | Intel Motherboard
No Connecton with wireless computer
it just means tat the connection is secure
wat you could try would be
1) take out power for modem then dynex router
2) power the modem n then router
3) if this doesnt work you would have to redo the wireless setting on the computer
Dec 23, 2008 | Linksys Wireless-G WRT54GS Router...
My cpu doesnt turn on what should i do??
so, your computer is not running, is that correct? do you get any lights on the desktop front panel? did you check the power supply for the proper rating on the switch?
Mar 10, 2008 | Gateway GT4022 PC Desktop
Viewmeter on Viewsonic crt monitor
just check the power cable from the monitor is connected correctly and plug from cpu to monitor is connected properly be sure is there an loose contact... if it doesnt works means then give reset button in monitor... check the power and frequency control properties in bios .... may be properties is user define or is in maximum saving mode just change it to mininmum saving mode ...it will work...
Feb 06, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
E-Machines (T2824) PC Desktop Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
