Question about Garmin StreetPilot c340 GPS Receiver
My Garmin c530 GPS will not turn on
I have the Garmin c530 and I was using it then it turned off. I figured the battery died and plugged it into my car charger. I tried to turn it on and again and it would not work. So, I brought the unit inside and tried to charge using my computer, and that did not work. Is the unit's internal battery bad? If so, can that be fixed? How much does the repair cost?
  • 385 Answers
Pull the face off it, press the reset button, this may work,
If it will not reset, or work in the house or the car, the battery will need replacing,
http://www8.garmin.com/support/outofwarranty.html
Around $100 for new battery
Regards.
Posted on Jun 22, 2009
While plugged in, my Garmin c530 will shut down immediately after it says "loading maps". Why is this?
This problem only comes up when the battery is not properly charged, therefore not being able to power up the gps beyond the loading map page. Try to reset the unit by holding the power button for about 15 seconds, it will restart the unit, once it restarts it, check if it will get pass the loading map page. Then you try to back up the software on a computer, format it and restore the software back on the unit. If that does not help, then you carry out the following tests.
Try to charge the gps device for about 2 hours then try to turn it on. If it does not come on, then it means the battery did not get charged. That can be a problem from either the battery or the charger or the charging port.
First test the battery by fixing it in another gps and charging it for about 2 hours then turn it on. If it powers on the gps, then it means the battery is okay, but if it does not turn it on, then it means the battery is weak and cannot hold a charge and the solution is for you to replace the battery.
Next you test the charger by trying it out on another gps device, if it turns it on, then it means the charger is intact but if it does not turn it on, then the fault is from the charger.
Finally, test the gps itself by trying to charge in by connecting it to the computer using the USB cable, then you turn it on, if it does not come on, then it means there is a problem with the connection port or there is an internal problem or something with the unit.
Hope this advice was useful to you.
Jan 02, 2011 | Garmin StreetPilot c530 GPS Receiver
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. http://www.garmin.com/garmin/cms/site/us/support/supportcontactand the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
Garmin C530 won't power up. I fully discharged battery and recharged. Unit gets warm while charging, still won't turn on. Replaced battery, charged..gets warm...still won't turn on. Are there any other...
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Aug 26, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jul 10, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 does not turn on
Replace the battery 3 years is the maximum life of the battery
Jun 11, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Touch screen doesnt work all the time
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Regards
Richard.
Apr 15, 2009 | Garmin StreetPilot c530 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 won't turn on
Have a c530 I purchased 11/2006. In 12/2006 had 3 instances where I shut unit off and it would not turn on. Garmin had me do resets which did nothing. Had to leave unit to discharge for 3 days, then plugged in USB and it powered up and was fine (for a week or so). They gave me a new unit and at the same time a system software upgrade was available. The c530 was perfect through all of 2007. Then in Jan 2008, the same failures occurred 3 times. I discharged it 3 times and it now works, but for how long? My advice is to get anoher model. I have 5, c330's for over a year and they have had 100% reliability. l
Jan 25, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
According to technical support, the "glitch" has been fixed with the latest web updater on the Garmin site. In the meantime, you will need to leave the unit unplugged for upto 48 hours to allow the battery die and the unit to get out of its "hang up". Once the battery is completely dead, plug the GPS into a computer (USB) and it should come back to life. Then do the update.
Hope this helps.
Nov 02, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
622 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
