Question about Canon NP 6650II Copier
Jam paper or? on np6650 11
When i try to make a copy it shows jam and it stops and i looked all over inside out and dont see any paper or any thing onit that got jamed help please i just got this used machine and is the first time am trying to make it work
  • 5 Answers
That could be a bad sensor.
Posted on Jun 21, 2009
LED 905 must be on....... so i'm clean that area of this sensor...... Developing, cassete area.
try this one.... Insya Allah.
Posted on Jun 05, 2010
My hp deskjet f2430 is showing that there is a paper jam. I have put paper in the printer and it still shows that there is a jam. How can i fix this?
A paper jam usually means that there is paper stuck inside the printer, I would start by taking a flashlight and looking inside the printer were you put the paper in and make sure there is nothing in the way there. You can also try to open up the printer, most have a few places that you can take apart easily and look inside to make sure there is nothing jammed. If you cannot get into the printer then the next best thing would be to take the printer down to a local computer shop and see if they can tell if there is anything in there really quick. Most decent shops will not pay to look into the printer really quick.
Apr 05, 2011 | Office Equipment & Supplies
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Red light on Printer doesn't want to print anymore
pull out the cartridge and look for paper inside, re-install cartridge, also look on the back part where the fuser and exit assembly is look for paper jammed. also make sure the paper is set correctly on the tray.
Jan 06, 2008 | Brother HL 1430 Laser Printer
Check paper light is blinking, there is no paper in the feed, checked to see if there was a jam, nothing.... The 'copies' constantly shows an E?
put the paper in paper try properly like put deep inside and stop it when you feel littel bit of resistent put slowly inside the paper.
Sep 05, 2007 | HP PSC 1210 All-In-One InkJet Printer
Canon NP 6650II Copier Logo
190 people viewed this question
old marine
old marine
