Question about Bravetti Triple Treat Ice Cream Maker
Bravetti ice cream maker problem
I have instructions but it only makes cold liquid. Froze containers 3 days but ice cream never gets solid at all.  Has anyone had this problem?
    New Friend:
Where can I find bravetti ice cream maker storage lid model#kp160h
Posted on Jan 15, 2014
    President:
  • 3,433 Answers
Is the mixture being stirred? Enough Ice and salt? Is the mixture correct?
Posted on Jun 21, 2009
Problem with my chocolate side. Will not remain as firm ice cream. Becomes liquid ice milk. I turn chocolate side off. After I turn back on it may still be liquid but not firm ice cream.what can I do?
Homemade Ice Cream Mistakes-and How to Avoid Them ...
www.bonappetit.com/test.../common-ice-cream-mistakes
Bon App?titJul 30, 2014 - Ice cream machines are easily found and affordable, so procuring the ...Once ice cream is properly chilled, it should be firm but not a solid, ...
5 Mistakes to Avoid When Making Ice Cream - Cooking ...
www.thekitchn.com/5-mistakes-to-avoi...
Apartment Therapy's The KitchnJul 20, 2015 - Not letting the ice cream maker bowl get cold enough. ... churning away in the machine, this process doesn't end with the firm, super scoopable ...
Will a new ice cream maker make my ice cream set firmer ...
www.chowhound.com/.../ice-cream-maker-ice-cream-set-firmer-964328
Feb 12, 2014 - I've been making ice cream at home for a few years now and tend to have pretty mixed results with how firm my ice cream gets. Even with all ...
Jan 10, 2016 | Ice Cream Makers
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Doesn't freeze consistently
Here is a tip that will give you the information you are looking for...
Ice Cream Maker Parts, Instruction Manuals and Recipes
http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
heatman101
Jul 13, 2010 | Rival 8704 4 Quart Ice Cream Maker
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Need Manual/Instructions
after much searching, i found the instruction manual for this unit in pdf format, @ http://dl.owneriq.net/e/e2989a56-98b6-67c4-69f8-21ce50aeb9b1.pdf
Aug 02, 2008 | Bravetti Triple Treat Ice Cream Maker
Instruction manual
Can I have the make and model of the ice cream maker please?
May 07, 2008 | Back to Basics ICM32 10-MInute Ice Cream...
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Bravetti Triple Treat Ice Cream Maker Logo
251 people viewed this question
Top Bravetti Ice Cream Makers Experts
Marvin
Marvin
ray gallant
Ruth summersides
Are you a Bravetti Ice Cream Maker Expert? Answer questions, earn points and help others
