Question about Sony Handycam DCR-TRV320 Digital Camcorder
Top control touchpad not working plus zoom extending.
My DCR-TRV320E will not respond to the top touchpad on the loading flap while closed and the zoom extends fully and will not retract.Leaving the top loading flap open enables the zoom to be retracted and some of the touch keys to operate.
Can this problem be solved by replacing the touchpad or perhaps the loading flap itself.
Problem is driving me nuts as I use the camera frequently.
  • 10,594 Answers
Its problem of that loading flap (technical name is control switch block) and requires replacement.
control switch block is included play-stop-rew-ff-eject etc switches including zoom-wide switch.
Posted on Jun 21, 2009
Why have some of the control pushbuttons stopped responding?
If your u it has a touchpad, the keys are worn out and the touchpad will have be replaced.
Jan 03, 2016 | Maytag Neptune MAH5500B Front Load Washer
Zoom control not responding
Well there is only one suggestion I can make and it is the camera needs service / repair by a shop.
Jan 19, 2013 | Nikon COOLPIX P90 Digital Camera
Dot s touchpad not responding
Use an usb mouse to select control panel and then select device management. From there you need to select the mouse and from there select the mouse and right click on it. Select to uninstall the device. Then close all screens and shut down computer. Unplug the usb mouse and restart the computer. If after it completes loading and it doesn't work the you will need a new touch pad. But if it does work it means windows had an corrupt update which caused the problem. Thanks Igor!
Sep 29, 2012 | Computers & Internet
He2 plus front load washer keeps showing f21 error code i cleared the drain pump filter and it still displays the error code f21 how do i check to see if the pump is not working
Hi
CCU/Touchpad/LED assembly error (f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. This will reset the CCU, and may reactivate the communication if the damage isn't severing. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU).
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
Jan 16, 2010 | HP Pavilion Dv3-1075us Notebook
Kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Sep 18, 2009 | Washing Machines
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Sony Handycam DCR-TRV320 Digital Camcorder Logo
296 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
