Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
T3626 Same issue here!! As soon as Vista OS starts to load it turns off. Choosing safe mode, it turns off. When you boot from Vista DVD, turns off. Customer said they took it to a the major chain store they bought it from and the tech informed them it's just now out of warranty. He opened the case, looked in, and said the motherboard had bumps and they needed a new one. So apparently it's a known issue. I'll prolly get a different mobo for it.
  • 3 Answers
Blown capacitors on Motherboard...Buy new board
Posted on Sep 19, 2009
    Problem Solver:
  • 13 Answers
I think mother borde is conected after the instulation of Windos vista .if that the case vista will not able to identifi the drivers for the board and it gets restarted or off .solution is to re install.But you sead that even when you boot from a boot from vista dvd it tha same.
i theink
01.boot driver is noot set to the dvd driver
02.Bios might not soport vista need a update
03.bios is brocan
04.you bord desn't soport Vista
Posted on Jun 22, 2009
My comp says i need to turn off safe mode its preventing certain things from loading
Hi, open your computer in safe mode and uninstall some newly install software. Otherwise--
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 17, 2011 | Computers & Internet
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
I have an acer aspire laptop with genuine vista os. i didnt operate for quit sometime and now, when i wanted to use it. it even didnt boot giving me a message. 'boot manager missing'. what is the problem...
If your Windows Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.Boot off the Windows Vista DVD and then click Next at the first prompt:You should see a link in the lower left-hand side for "Repair your computer"The installation process will attempt to find your Vista installation directory. If there's more than one in the list, select the correct one and then use the Next button again.Click the first link for "Startup Repair".The installation process will repair the system, and then prompt for you to reboot.Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot.
At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Sep 19, 2010 | Acer Aspire 4730-4947 Notebook
When powered on it says os not found
Make sure that there is NO CD or DVD disc loaded in the CD/DVD drive while you are turning your laptop ON. Eject all CD/DVD discs are restart.
Nov 10, 2009 | Gateway MX3560 Notebook
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Laptop restarts over and over
Is it Win XP or Vista? hit F8 and see if you can get into Safe Mode, if you can goto start , run and type msconfig, disable all and reboot.
If you cant get into to safe mode, hit F8 when computer turns on and scroll to Last Known Good Configuration. see if lets you in.
If you are running Win XP and none of that works. You will have to run your XP CD and do an OS repair, just load the XP CD at boot when setup starts hit ( Enter F8 then R) let it do its thing. Hope this helps Good Luck.
Jul 24, 2009 | Computers & Internet
Windows vista will not load
I wouldn't suggest Vista OS because it is very buggy.. but try booting into safe mode by pressing f8 when the computer first starts up. Keep pressing it so you dont miss it then boot into safe mode and try to diagnose why it didnt start correctly
Jan 18, 2009 | Computers & Internet
Computer crashed, won't go to windows
When you start you computer, after the bios flash. press the F8 on your keyboard before the Windows start loading. You should have an option to select to go to safe mode.
Select the safe mode option only. See if it will load the Windows under the safe mode option. If it did load the Windows under safe mode. There is an issue loading the driver of your Windows O.S. that i why its not booting under the Normal mode. Sometimes this is cause also by a Virus on your computer. You can run the Anti-Virus program under Safe mode to check for viruses
To fix this you may need the Original Disc of Windows O.S.
You can reboot the computer. Load the disc make sure that under the Bios option the CD drive is the first boot. Then save it.
after rebooting. Follow the on screen instruction on how to repair the O.S. There should be an option to repair the O.S. when you boot the computer using the Windows O.S. Disc
Note:
If you could do a backup of your files, do it first before repairing the O.S.
If it will not resolve the issue, you will have to reformat your computer.
Sep 09, 2008 | Computers & Internet
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
392 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
