Help can't make it to work dTV
    Sergeant:
    Champion:
  • 255 Answers
Is it dTV compatible or have features associated with dTV?check the manual for details.
Posted on Jun 21, 2009
Cant get dtv to work on panasonic
Do you live where DTV is available? Does the TV support DTV? Are your signal levels adequate? Have you switched the set to its DTV setting? Have you run an autoscan?
Jul 17, 2010 | Panasonic Televison & Video
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
I've got a Baird HA32R1,$ DTV doesn't seem to work!
TRY TO SET TELEVISON TO FACTORY SETTING......TO DO THIS GO TO MENU ON UR REMOTE CONTROL AND SELECT SET UP
WHEN THERE FOLLOW THE PROMPT AND SELECT FACTORY SETTING......ALL UR PRE TUNED CHANNELS WILL GO ........AND U HAVE TO REINSTALL THEM WITH AUTO TUNING ALL UR CHANELS WILL COME BACK...........
Nov 19, 2009 | Televison & Video
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
My dtv keep saying nosignal antina hooked up .protron tv was working fine ran scan station. stop playing
dtv needs a strong signal to keep track of the channel. The antenna is good inside the room but tends to be affected for interferences. to catch signal (as in the past with ear rabbit antena) is difficult inside the room. and roof antenna is better but needs a good installation. the cable channels can work digital without the dtv. Is hard to give you any idea besides this ones because i don't know how the set up[ is in your case problem, but i hope i could help you a little. Now if the antenna is rasonable good and still having problems with your channels the suspect the dtv failure.
Apr 24, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Magnavox 27mdtr20 17
The Magnavox 27mdtr20/17 is a standard def. television produced in 2003 by the Philips-Magnavox Corporation. This particular model was conceptualized long before DTV was an option, and much further before Digital Television Broadcasts were considered a viable option for our current current communications problems.
You will need a DTV box IF:
A) You use an antenna (roof top or otherwise) to watch television
You will not need a DTV converter box IF:
A) You subscribe to cable services, either analog or digital
B) You subscribe to satalite services
For more information on the reasons behind the DTV transition, as well as getting valuable cupons from the federal government to help subsidize the cost of a DTV box, please visit this site:
https://www.dtv2009.gov/
I hope this helped,
Remy
Dec 23, 2008 | Philips 27MDTR20 27 in. TV/VCR/DVD Combo
Grundig gu15wdpcx. unable to access any of the dtv menu's not even to scan for channels etc, please help
With this model you can access everything apart from the DTV menus inc DTV tuning without the remote, for DTV menus and tuning you must use the remote.
Apr 03, 2008 | Televison & Video
Mintek DTV-373-D Remote code
As far as I know, no regular universal remote will work with the mintek TV/DVD's.
I have heard that the "Kameleon" remote, from radioshack works with them.
I had the same problem, so I ordered a replacement original remote from ebay for $20. It was the RC-600 for mine (DTV-265 26" LCD/DVD)
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd=1&item=360029014984&ssPageName=STRK:MEWN:IT&ih=023
Feb 11, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Jan 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Phone connection problem
Yes, it looks like the thunderstorm has damaged your DTV unit because the DTV unit should only go off hook as a means of dialing the DTV Company. I would have that unit replaced. BTW, do not try to repair that DTV unit. I work for a Telephone company in the Maryland DC area and I can tell you there are no serviceable parts inside and the unit is not your to do that anyway. So call the DTV Company and have then replace the defective unit.
Aug 31, 2007 | Samsung SIR-TS360 DirecTV DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
