Question about Samsung Office Equipment & Supplies
Samsung CLP-300N color laser printer, Tries to startup - makes sounds , but stops immediately with a red light. No toner lights are on. Checked repeatedly: No paper is stuck.
  • rpm22by7 Jun 22, 2009
    There are no lights in the front. On startup the printer tries to go through its process - makes noises goes through the four toner color lights check and then begins like it is about to proceed normally, but abruptly stops and the status light turns RED. The paper is 3/4 full in the tray below, but the printer does not even try to load the paper. There are no jams and no bits of paper stuck anywhere. All toner lights are blank indicating that the toner is NOT empty. When I turn it OFF and then ON, the Status light turns Orange then changes to Green and then the printer begins its checks, makes noises and then abruptly stops.
    President:
  • 1,996 Answers
Here is the home online support page for your printer. You will note there is a troubleshooting section that allows you to access error messages for your printer. In this section the following information about the stop condition is found:
Error Messages > On Line LED Is Solid Red which has instructions that indicate either a cover is not closed completely, a toner cartridge is not installed completely, the paper is installed incorrectly, or the cartridge is low on toner, etc.
Please try to work through these articles, here and here, just to be sure it is not a paper or cartridge install issue.
Here is a link to download a pdg manual for your printer, which includes a troublshooting section.
  • Make sure the printer cover is closed
  • Check the paper load in the paper tray, then Press the stop button on the smart panel program window to make sure the printer is not in manual feed mode.
  • See page 43 of the user's guide to understand the meaning of the error lights.
  • Try removing the toner cartridge and redistributing the toner according to the instructions on page 29. Then try to print a test page. Sometimes this will get you added life from your cartridges.
  • Note that even though your last printed page was not faded or improperly printed, the counting software in the printer will sometimes require you to replace the toner cartridges even though they are still printing just fine. For some printers, there are workarounds to fool the printer that allow you to continue printing with old cartridges until the printed page fades, etc. I'm not sure if fixes like this are available for your samsung or not. You could search online. But it's possible that your only problem with the printer is the need for a need cartridge. Especially if redistributing the toner temporarily works to stop the error condition.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 22, 2009
  • 3,230 Answers
Well, it depends -- is the solid orange light on the FRONT -- which indicates that the printer is waiting for paper (either in the manual-feed tray if the light is near the top; or in the paper tray if the light is the one on the bottom).
If it is an red light on the TOP of the printer, it indicates a malfunction (paper jam, etc.)
Also, try turning the printer OFF -- which I presume you did when you took it apart!
Thanks
Posted on Jun 21, 2009
  • Mukesh Kumar Jun 22, 2009
    Do some cleaning to your printer, clean the roller of your printer.
Red light stays on and printer wont work
Check the waste toner bottle on the left side. If that is full, you will get red light. Just empty it if is full of waste toner. Re-use the waste toner bottle.
Mar 09, 2011 | Samsung CLP-300N Laser Printer
I net's this CLP 300n Driver
You can download the driver for this printer from this link.<br /><br /><a href="http://www.samsung.com/us/consumer/office/printers-multifunction/color-laser-printers/CLP-300N/XAA/index.idx?pagetype=prd_detail&amp;tab=support">http://www.samsung.com/us/consumer/office/printers-multifunction/color-laser-printers/CLP-300N/XAA/index.idx?pagetype=prd_detail&amp;tab=support</a><br /><br />
Aug 24, 2010 | Samsung CLP-300N - - color - laser -...
RED status light in Samsung CPL 300N Last time I got solution list in which my printer was not even mentioned
try downloading the manual from here.
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=CPL+300N+&input_keyword=CPL+300N+
Apr 22, 2010 | Samsung CLP 300 Laser Printer
I have a samsung clp 300 which goes through the motions of pre printing & then stops.the red button clicks on & off. I have reloaded drivers, this does not help either
According to the CLP-300N User's Guide page 42, the problem could be
"The waste toner container is not installated or full. Check the container."
Open the front cover, the waste toner container is on the far left side in "L" shape.
Gook luck!
Feb 10, 2010 | Samsung CLP 300 Laser Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-300N printer shows faint banding
Developer roller worned,common problem.roller can be changed,take drum out,2 screw 1 on the side near toner excess bin and 2nd on roller.
Jun 24, 2009 | Samsung CLP-300N - - color - laser -...
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
71 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
