Question about Canon PIXMA iP4000 InkJet Photo Printer
Reset the ink waste tank code, and now pixma ip4000 won't turn on
Ink wast tank error came up, so dismantled printer and cleaned the blotters. Then reassembled and reset the ink waste code. That went like clockwork, but now the printer won't turn on at all. I have unplugged the power cord and replugged it back in, but nothing. Please help.
  • vaughanlm Jun 23, 2009
    Thank you Komguy, that was the problem
  • Anonymous Mar 20, 2014
    Has been working just fine, never a problem with it. Moved my study around and unplugged / replugged it back in and wont power up. No lights, no noise, nothing.
    President:
  • 2,306 Answers
Try removing the printhead and power up, if it works you need a new printhead. Many times when the printhead goes bad the machine won't power up.
Posted on Jun 22, 2009
What are printer error messages 4F and 48 on Bother MFC-J430W wireless printer
Error 4F and Error 48.
Actual Message will be:
Unable To Init 4F
Unable To Clean 48
These messages indicate the Waste Ink Tank is full.
This is the space in your machine that will store all the ink that is used in cleaning the printhead. Once this is full the only way to continue printing is reset the Purge Counter and clean out the Waste Ink Station. If you do the reset and not he cleaning of the waste ink station you will eventually end up with the waste ink tank overflowing and leaving a huge mess to clean up. If you clean out the tank but not reset the purge counter it won't work till then.
Unless you are satisfied with your ability to dismantle and reassemble your printer you may want to just replace it as it can take some time and causes alot of mess.
May 01, 2016 | Brother MFC-J430w Inkjet All-in-One
I have canon printer pixma ip 1200, what is the meaning or "The waste ink absorber is full ?"
there is NO ink tank in your printer! All printers send allwaste ink to the blotters at the very bottom of your printer. Not all your inkis used up on your prints and photos - much of it is over-spray or the excessused in printhead priming before, and cleaning and wiping after, a print job is finished. Yes, there's a lot ofink down there!
Can a printer owner fix this problem at home? Well, the answer comes in twoparts, the first is easy, and is answered by the procedures below - the wasteink counter can be easily re-set, and your printer will once again beginprinting. The second part of the answer is that unless you take your printerapart and clean it out, you will eventually - sooner or later - face a scenariowhere the waste ink in your printer will begin to ooze out of the bottom ofyour printer (I will answer this second issue with a companion article to thisone - link under Resources below).
I am most familiar with Canon printers, and will use one of Canon's mostpopular recent printers, the Pixma iP4000 as an example of the waste tank resetprocess. This same process should work with all of Canon's Pixma printers, andmay even work with other Canon printers as well..
Does Canon want you to know this information? Of course not! Will it extend thelife of your old faithful printer? Yes it will. And this is especially good ifyour old printer is one of those that uses generic, compatible ink cartridges,which are much less expensive than today's "chipped" ink cartridges.So, keep that baby alive, and feel good about it.
1.We'll assume that you've already removed the outside caseof your printer 2. Once the case is off, you're looking at the guts of theprinter sitting in the tray-like base. To get at the blotters and waste ink,you'll need to get under the printer body, which is held to the base by threeor four screws. The older your printer is, the easier it will be to find thescrews that hold the body to the base, and the more working room you'll have.If you have a good magnetic screwdriver, that will be very helpful. It may alsobe helpful to take notes and/or pictures of where the screws are located tomake re-assembly easier.
3. Use your flashlight or lamp to illuminate the rear corners of theprinter base. You should see a small screw on each side with an access for yourscrewdriver to it - remove each of these screws, and the body of the printershould be freed-up from the rear of the case. Now look for one, or usually, twomore small screws on each side of the case bottom toward the front. With theremoval of these screws, the printer body should be able to be raised at therear and lifted backward out of the case. Some models have a hidden screw ortwo, which might even require the removal of the power supply, or the movementof wire assemblies to get at the screw. But there always will be a way.
4. Put on a pair of latex gloves. With the printer body removed from thecase, and set aside on some newspaper (it may/will be very "inky" onthe bottom!), you are now looking at the blotters which have received theexcess ink - see the top pic. Again, it's a good idea to take notes or picturesto indicate the location of the blotters. There are usually several large andsmall ones. Remove them to plenty of newspaper and take them to a utility sink,idealy in your garage or the utility room
5. The cleaning of the blotters will take huge amounts of running water!Hold the blotter under a stream of running water as it flushes the waste inkout. This will take a long time - maybe 10-15 minutes for each one. No, youwill never get them white again, but your goal is to remove enough of the wasteink that eventually, the wash water is just slightly inky and the blotters aregrey. You may gently squeeze them as you wash them, but this may damage theblotters, so go gently. When you decide they've had enough cleaning, let themswell with warm water until nice and plump, and do not squeeze this water out.Put them outside in the full sun on some thick newspaper to fully dry -occasionally turning them over. If it's raining in your area, you may choose todo the drying in your oven - use only the oven light, which should push thetemp to near/over 100 degrees, and lots of newspaper.
6. While the blotters dry, take the printer tray/base to the sink andgive it a good cleaning. Make up a Clorox/water solution to help remove inkstains from the base and the outside of the case too. When the blottershave dried - two days is not unusual - you're ready to begin the re-assembly ofthe printer. Use your notes/pictures if you've been smart enough to have them.Replace the blotters. The printer body will slip into the bottom of the casefrom the back toward the front. Replace the screws. Remember to re-route anywiring, and to reconnect plug-ins. It's a good idea to power it up before youput the case back on, just to make sure all is well. Replace the case, andpower it up.
7. f you're lucky, you will no longer see the flashing error code lights(they are different on many models, but usually on the Pixmas, you'll see asequence of 8 orange flashes followed by one green). If you are still seeingthis error code flashing, you'll need to reset the printer's internal setting -to do that, see the last link in the Resources below titled, "How to Fixthe Dreaded Waste Tank Filled Error Message for Your Canon Printer". Andif you continue to have issues, check out one or two of the suggested PrinterForums listed below.
With the printer power turned off, while pressing the Resume/Cancel button,press and hold the Power button. (DO NOT release the buttons. The LED lights ingreen to indicate that a function is selectable.) While holding the Power button, release the Resume/Cancel button. (DO NOTrelease the Power button.) While holding the Power button, press the Resume/Cancel button 2 times, andthen release both the Power and Resume/Cancel buttons. (Each time theResume/Cancel button is pressed, the LED lights alternately in orange andgreen, starting with orange.) When the LED lights in green, press the Resume/Cancel button 4 times - Wasteink counter resetting. (Each time the Resume/Cancel button is pressed, the LEDlights alternately in orange and green, starting with orange.) After the function (menu) is selected, press the Power button. The LEDlights in green, and the selected function is performed. (When the operationcompletes, the printer returns to the menu selection mode automatically.) If the printer is now off, the process is finished, otherwise press thePower button one more time to set the function and to shut down the printer.
Feb 23, 2011 | Canon Office Equipment & Supplies
The large black ink tank doesn't deliver at all. I have: cleaned, deep cleaned, downloaded the newest drive from the Canon site, replaced the tank more than once, done the nozzle alignment, replaced the...
The error could be that the waste ink is full. They count the number of cleanings and shut down the printer when the waste ink pad gets full.
One can clean the pad by rinsing until it is almost white and then use special software to reset the counter in the printer.
Look up maintenance software for your printer.
One has to disassemble the printer to get at the waste ink blotter.
Dec 11, 2009 | Canon MP970 Photo All-In-One InkJet...
WASTE INK ABSORBA FULL
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 23, 2009 | Canon Office Equipment & Supplies
Error Code 5 on Canon MP160 Printer
your problem is waste ink absorber is full,you need the canon mp tool which is use to reset the counter of your printer,but you must dismantle your printer to clean the waste absorber because if you will reset the counter without cleaning it, all waste ink will overflow on your printer.
Apr 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
CANON PIXMA ERROR 5800
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma mp110
waste ink...pad is full..needs to be washed and dried, but you will need to reset the code in logic board. Search for it.
Jun 27, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Waste Ink Absorber full - Canon Pixma
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Mar 13, 2008 | Canon PIXMA iP90 Mobile Printer
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
628 people viewed this question
old marine
old marine
