Question about Cuisinart Brew Central 12-cup Coffee Maker
The grinder is making a noise and not grinding beans
  • 2 more comments
  • willmcdonald Jun 22, 2009
    It seems to be slipping on the shaft.
    How do I fix it?
  • Ned C Cook
    Ned C Cook May 11, 2010
    can you verify the fact it is slipping? We can fix that. That is usually caused by misalignmentt andBIG beans.. kidding on the bean. -Ned
  • Ned C Cook
    Sounds like worn gears?
    President:
  • 3,433 Answers
If the gear is slipping we need to know how it is helld on the shaft. Look between the teeth on the gear to see if there is a set screw. If so, using the proper tool, loosen it and try to remove the gear. Then, go to a auto parts store and buy a small tube of loc-tite thread lock, put some on the shaft and slip the gear back on, then tighten the set screw firmly. The loctite will set up in an hour and fully dry in about 3 hours. Good luck and keep me informed please.
Posted on Jun 22, 2009
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 18, 2014 | Coffee Makers & Espresso Machines
Grinding makes a lot of scratch noise and coffee wouldn't drip. The machine says to fill the beans but container is full.
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 27, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a Breville BES860XL and the grinder is not working. If i overide the interlock, It will spin, but does not have enough power to grind beans
It seems there's a fault in the grinder gearing in this particular model.There's no solution but to take it to Breville repair...
I have the same problem and so does a friend of mine. The grinder will spin without beans in the hopper but as soon as beans are introduced the grinder makes a loud noise. Like the gears are slipping and there's not enough power to grind.
Jun 10, 2011 | Breville BES860XL
Attemps to gind but no beans seem to get through Then the display indicates 'add beans' although it is full
Machine thinks there are no beans because it is not grinding. Most likely the grinder is blocked. The common causes are a small foreign object, a stale hard bean and moisture (either from water spillage or moist beans). The first thing you should do is vacuum ALL the beans out, set it to the coarsest grind setting and run the grinder a few times ( with no beans). Then put a small amount of fresh beans (make sure they are dry and not from fridge or freezer) in and try again. Give it a few goes. If it still wont grind have a good look down there, if it looks wet let it dry out for a while and try again. If none of thes easy tips help you will have to remove the top grinder burr and clean both burrs. Good luck.
Dec 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee machine will not grind the coffee beans?
Since your grinder makes noise and the problem occured suddenly, I would rule out a grinder problem. I am guessing that your grinder runs 10-20 seconds before it stops. If that is the case you need to look for a obstruction in the grinder or a failed microswitch on the doser. Either of these could cause the problem.
Dec 13, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
The grinder itseld seems to be working because it makes the grinding noise. However, the beans are not going down the shaft into the grinder. I have cleaned out the top and removed the container holding...
Make sure the filter basket is in the open position, and that the area that runs from the grind basket to the filter basket is free from grinds and mositure.
Jun 28, 2008 | Cuisinart Thermal DGB-600 Grinder
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
