Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
My steamvac leaks from the clean water tank
When i attach the clean water/ solution tank on to my steamvac it starts leaking i took it apart and it leaks from where the attachment hose is suppose to be hooked up even when the hose is not in use leaking on to the motor and inside of the machine!
  • Joyce Amber Mclaughlin Jun 21, 2009
    my hoover is not a f6212 its an f5906-900
    Sergeant:
    Champion:
  • 255 Answers
Try to look for small holes or cracks and even the tank.use clamps to make sure your hose is firmly attached.
Posted on Jun 21, 2009
    Problem Solver:
  • 7 Answers
You have either a cracked housing, or a valve is stuck open. if you can spray a small amount of wd49 into the valve, and work it a little, youmay be able to dislodge whateverdeposits have built up in there.
How do you remove the lower handle?
Check the clean water holding tank. I had this problem and found that was a crack near the outlet on the bottom of the tank. I replaced the tank and resolved the problem. I have taken this machine apart several times, if the tank is not the problem with yours, check the water tube.
Apr 26, 2015 | Hoover F7425-900 SteamVac V2 Widepath...
I took my nozzle apart on my hoover steam vac because it leaked water all the time, now I cannot get the back together
The Hoover SteamVac is an upright, self-contained carpetcleaning machine. The machine features five rotating brushes and on-boardstorage for a hand-held upholstery tool with an 8-foot hose. But itis not that much difficult to re-attach the Hoover SteamVac nozzle. Here, a weblink, with full procedure and diagrams, which will help you to re-attach iteasily - http://hoover.com/file/624/. Hope this will help you. Good Luck.
Aug 18, 2011 | Vacuums
The clean water tank is leaking terribly
This was a common problem for the models that were manufactured with a two piece tank. These tanks will have a colored soap container attached to a clear water tank. The plastic was too thin around the valves and would crack. You need a new style one piece tank ( # 42272104 ).
Mar 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Water is leaking from bottom of cleaner
you may just have a split pipe from the water tank and thats why its leaking water out
Jun 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning solution leaks
It could be the lid on the container. If it isnt lined up absolutely perfect it tends to leak. You could make it tighter with a bit of ptfe tape. As these containers go into the machine lid down this is here mine leaks if Im not very careful.
Jun 13, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Dirty water is leaking back out
After shut off all steamvacs will leak dirty water that was sucked up back out. There is always some left in the nozzle. If it is a large amount there is clogged filter that isnt allowing the proper suction. Refer to your manual or go to hoover.com to download one for cleaning directions.
Jan 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Constantly sprays water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=515776&thid=544922
Posted by elstretcho on Apr 25, 2008
Hoover F7452-900 SteamVac Upright Vacuum
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, its leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and its still doing it. Any ideas?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a bad trigger release valve or a loose connection @ the bottom of the SteamVac or the gasket under the solution tank in not sitting on there right and is leaking or you may have a small cut in the hose, but it so may guess that it is a bad trigger release valve or a bad gasket. Check with your local vac dealer to see if they have a new or a good used one to see if there is the problem or back track the problem from the bottom to the solution tank. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Problem hose
Try gently feeding a thin, springy wire down the tube to find is there is a blockage further up.
Mar 22, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
423 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
