Question about Sharp XR-40X Projector
My Sharp XR-40X DLP Projector bulb will not start. The bulb is not near the end of it's projected life nor did I get the "Replace Bulb" warning indicator. It has power and the fan comes on.
  • 31 Answers
Hi Just be aware that the stated lamp projector specs "2000 hour lamp" does not mean you will get 2000 hours. What it means is that the lamp is rated to deliver up to 2000 hours. So some might get 1000 hrs, others 1593 hours etc.
The lamp may have died of its own accord prematurely and obviously unexpected.
With the power and fan coming on my first throughts are either the lamp or the lamp ballast (powers the lamp).
If you need a lamp we are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US337 with lamp housing or lamp only $270. includes freight. Excludes any import taxes. http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Posted on Sep 10, 2009
SOURCE: sharp xr-10s /sharp xr 10sl are they the same unit?
Hey, XR10S and XR10SL is the same. The Lamp is SHP93 if for Replacement.
Posted on Jul 01, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XR-40x Projector will not power up
if the lamp hours are over the limit, you need to reset the lamp timer by holding down the enter, down, and menu buttons and press power. if that doesn't work and you're not getting any leds lit on the control panel, replace the power supply.
Posted on Jul 08, 2009
projdoc
  • 2237 Answers
SOURCE: my sharp xr-20x projector wont turn
are there any leds on? if not, the power supply is shot. if there are leds on, the color and number of flashes will tell you the problem.
Posted on Aug 12, 2009
  • 3 Answers
SOURCE: Cannot remove lamp assembly from Sharp XR-10X projector
Carefully try using a flat head screw driver on the middle plastic piece. make sure it is off...
Or try coming at it from the other side after taking the top of the machine off you can unscrew 3 screws and loosen whatever might be blocking it
Posted on Sep 08, 2009
  • 7 Answers
SOURCE: I changed the bulb on the Sharp xr-32x and it
Per the manual, hold down MENU button, DOWN button, and the ENTER button, then press the STANDBY/ON button.
Posted on Sep 05, 2010
My projector's power light is red, but when I click power it won't turn to green (on)
The likeliest problem here may be a burned out or failed projector bulb. Most projectors will fail to power up at all when if the bulb is out. The HD20 user manual does not specify a red light as an error indication option however, generally amber.
User manual .pdf is located here (takes a bit to download for it's size), Projector Status Indicator instructions are located on page 40.
Here on the product page itself, an email to Optima support may be warranted given the red instead of amber error light.
If you had any messages recently indicating your bulb life was nearing it's end, again, this would be my first guess. Certain models of projectors do have a tendency of blowing through bulbs even before any warning message comes up. I had an experience with a certain brand/model that for the last 3 replacements has given only about 1/4 of the stated bulb life, so unfortunately it does happen.
Mar 05, 2011 | Optoma HD20 DLP Projector
Sharp projector lamp will not come on
It is mother board problem.Reverse side of the board 5 pin ic not giving 12 volt.pin no. 1 input 12volt and pin no.3 12 volt out.it might be damage
Feb 26, 2010 | Sharp XR-10S DLP Projector
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
Feb 22, 2010 | Office Equipment & Supplies
Projector turns on but does not illuminate bulb is good
may be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
Dec 11, 2009 | Sharp XR-10S DLP Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Mar 09, 2009 | Sharp XR-40X Projector
I have a Sharp XR1X, blinking green light will not start
very common with this model, the ballast board needs repairs / replacement.in this case the power & the ballast board is one single PCB
Feb 02, 2009 | Sharp XR-1S Notevision DLP Projector, 800...
Sharp XR 10X lamp replacement issues
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
Oct 01, 2008 | Sharp XR-10X Multimedia Projector
Sharp xr-10s /sharp xr 10sl are they the same unit?
Aug 03, 2008 | Sharp XR-10SL DLP Projector
Sharp XR-40X Projector Logo
337 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
