Question about ASUS CROSSHAIR Motherboard
Fan mount broken
The clip attachment for the fan on my mother board broke! Can I replace it"?
    Sergeant:
  • 173 Answers
YEs you can purchase new processor fan and also if you are some tech savvy then you can change its clip.
BUt new processor fan purchase is good choice becasue not cost of it.
Posted on Jun 21, 2009
Fan is working without 4 pin ATX pin but not with 4 pin ATx
Fans are Controlled by Temperature Control Setting of the Mother board. So the Fan controller is a function of the BIOS of the Mother Board...
Jul 17, 2014 | Intel Computers & Internet
Cooler repair
If the pins on the mother board are sheared off, you will have to solder the connections directly to the motherboard.
You may want to replace the mother board
Apr 03, 2014 | Computers & Internet
I can't get my CPU fan to connect to my mother board because the plastic clips are broken what can a do
What is the make and model of the motherboard and what is the make and model of the fan?
Mar 29, 2013 | Computers & Internet
Im having trouble removing the radiator from the
the cooling fan is not attached to the radiator. it is mounted on it's own frame attached on the sides with about four bolts.remove it first then disconnect coolant hoses and transmission lines from radiator and lift it out.
Apr 27, 2010 | 1996 Chevrolet Cavalier
How do you replace a radiator in a dodge shadow 1993
These are the instructions for a 4 cylinder motor.
  1. Disconnect the negative (-) battery cable.
CAUTION Do NOT remove the cylinder block or the radiator draincock with the system hot and under pressure because serious burns from coolant can occur.
  1. Drain the cooling system.
  2. Remove the hose clamps and hoses from the radiator. Remove the coolant reserve system tank-to-filler neck tube.
  3. Remove the automatic transaxle hoses, if so equipped.
  4. Remove the fan and fan support assembly by disconnecting the fan motor electrical wiring.
  5. Remove the fan shroud retaining clips, located on the top and bottom of the shroud for most of the vehicles (the Dynasty has them only on the top).
  6. Lift the shroud up and out of the bottom shroud attachment clips separating the shroud from the radiator. Avoid damaging the fan.
  7. Remove the upper radiator mounting screws. Disconnect the engine block heater wire, if so equipped.
  8. Remove the air conditioning condenser attaching screws located at the top front of the radiator, if the vehicle is equipped with air conditioning.
  9. Lift the radiator free of the engine compartment.
Care should be taken to NOT damage the radiator cooling fins or water tubes during removal or installation.
To install:
  1. Slide the radiator down into position behind the radiator support.
  2. Attach the air conditioning condenser to the radiator, if so equipped, with a force of approximately 10 lbs. (44 N) to seat the radiator assembly lower rubber isolators in the mount holes provided.
  3. Tighten the radiator mounting screws to 108 inch lbs. (12 Nm).
  4. Connect the automatic transaxle hoses, if so equipped. Tighten the hose clamps to 35 inch lbs. (4 Nm).
  5. Slide the fan shroud, fan and motor down into the clips on the lower radiator flange. Install new shroud retaining clips.
  6. Install the upper and lower radiator hoses (including the coolant reserve hose).
  7. Plug the fan motor electrical connection and attach the negative (-) battery cable.
  8. Fill the cooling system with coolant (refer to Section 1 for more details).
  9. Operate the engine until it reaches normal operating temperature. Check the cooling system and automatic transaxle (if equipped) for the correct fluid levels. Also check for coolant leaks.
Here are the instruction for a 6 cylinder engine.
6-Cylinder Engines
  2. Remove the hose clamps and hoses from the radiator. Remove the coolant reserve system tank to filler neck tube.
  1. Remove the automatic transaxle hoses, if so equipped.
  2. Remove the fan and fan support assembly by disconnecting the fan motor electrical wiring.
  3. Remove the fan shroud retaining clips, located on the top and bottom of the shroud for most of the vehicles (the New Yorker, Dynasty, Fifth Ave., and Imperial have them only on the top).
  4. Lift the shroud up and out of the bottom shroud attachment clips separating the shroud from the radiator. Avoid damaging the fan.
  5. Remove the upper radiator mounting screws. Disconnect the engine block heater wire, if so equipped.
  6. Remove the air conditioning condenser attaching screws located at the top front of the radiator, if the vehicle is equipped with air conditioning.
  7. Lift the radiator free of the engine compartment.
Care should be taken NOT to damage the radiator cooling fins or water tubes during removal or installation.
To install:
  3. Tighten the radiator mounting screws to 9 ft. lbs. (12 Nm).
  9. Operate the engine until it reaches normal operating temperature. Check the cooling system and automatic transaxle for the correct fluid levels. Also check for coolant leaks.
please let me know if i can assist you in any further problems you may encounter with your vehicle.
please do not forget to rate and comment about your experience with fixya today.
Dec 27, 2009 | 1993 Dodge Shadow
Fan motor works only on high, more likely to be a switch problem or a motor problem? What is simplest way to test?
Niether the problem is a module called Blower resister Module this resists the amount of power to the motor. These are reasonably cheap and take only a few minutes to change. It is usually located by the heater blower motor
Oct 19, 2009 | 1999 Plymouth Breeze
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
The fan motor/bracket that attaches to the mounting bracket is broke and i would like to know if this can be replaced
Call Hunter (800)893-9330 for a new bracket. They should replace the damaged bracket for free or a nominal fee. They have a potential liability if the bracket is defective. If you broke it, that's another story.
Jul 29, 2009 | Hunter 20347 Ceiling Fan
My heat sink clips on this plastic piece thats screwed into the mother board one of the taps broke off and the heat sink fan combo falls off the mother board and the computer over heats. what is this...
those r called as Heat sink Clip u can find in any radio shack or any HW Shop. make sure that befor u put the HeatSink put the Thermal Gel.
May 17, 2009 | HP HEAT SINK
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Open Questions:
How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 22, 2018 | Toshiba Computers & Internet
See all ASUS CROSSHAIR Motherboard Questions
ASUS CROSSHAIR Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
