Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
Dryer not drying after 1st load
I have a GE dryer (DDE720SBLWW) that is not working after 1st load. A little frustrating, but I'm hoping this is an easy fix. I don't want to buy a new dryer.....at least yet. Any guidance will be appreciated. Thanks.
  • 3 Answers
SOURCE: ge dryer
i built these machines... before doing anything ...check your fuse box or breaker .... 240 v .... it goes out often ... if its not that ... its probably your element ... ...open your door and on the top of the opening ... there 2 screw ... take the top off then the front ... 2 other screws ...take out drum ...and check element ... its about 60 for a new one
Posted on Nov 30, 2007
SOURCE: GE clothes dryer,model DPXR483EA1WW
Well this morning I got up and pressed the start button on my dryer and it's been working eversince. Thank-you I will contact you if I have any more problems. Jessica
Posted on Jul 18, 2008
  • 50 Answers
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Posted on Jan 25, 2009
  • 40 Answers
SOURCE: My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
Posted on Mar 09, 2009
  • 532 Answers
SOURCE: dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Posted on Apr 22, 2009
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
The dryer drum will not turn.
Could be belt gone if the drum is quite easy to turn by hand. Or motor in @worst
Apr 01, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE dryer cuts off around 10 minutes into most loads...
You have a bad motor. Could possibly be caused by lint buildup on the motor itself a loose belt or clogged external vent line.
Sep 22, 2009 | GE DVLR223 Dryers
Dryer takes a very long time to dry a load.
Some dryers have more than one heating elliment..
A way to check is -- take the exaust hose off.. Put a mirror so you can see into the hole & hopefully see the heating elliment(s).. When running they should glow like a stove burner..
If it is not gloing its not working & needs to be replaced..
I suspect that one may have went out..
I hope this helps !!
Please rate me good ;o)
Jul 12, 2009 | Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer
You have one of 2 things wrong. 1st, there is a thermal fuse that is in the back of the dryer. It is a disk with a fuse inside. Or the overload that is attached to the housing of the element. If you got a new one with your element then its the 1st. Cheap parts..can be found at www.Repairclinic.com or any appliance parts store. Good luck.
Apr 20, 2009 | GE DBSR453EBWW Electric Dryer
Ge dryer only dries small load
either your heating element or your limit switches are going out
Feb 04, 2009 | GE DHSR333EV Dryer
Ge profile harmony dryer
You most likely have a clogged venting system going to the oustside.. Try this pull the dryer away from the wall remove the flex venting pipe.
Run a load now yes i know the heat and moisture will come in the house but it is just one load(open a window) if it works ok then you will need to get someone out to clean your vent and your money back from the repairman who came out .....any technician worth anything should have told you this.....98% of long dry time calls are a plugged venting..just and FYI...Hope this fix ya if so plz rate
Jan 26, 2008 | GE Profile Harmony DPGT750EC Electric...
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
57 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
