Question about Ruud UAKA037 Air Conditioner
Too much water condensation
I have a Ruud HVAC unit which has an air intake filter located at the bottom of the indoor unit. I notice a steady stream of water drip where
the indoor evaporator unit is located -- the water drip is where the air intake filter is located.
Is this a simple problem to fix or do I need to call a HVAC mechanic?
Thanks in advance for any help.
  • 29 Answers
Check your condensate drain. It could be plugged. Or perhaps you have a crack in the drain pan.
Posted on Jun 21, 2009
Ruud ubha-21j00nuaa
Can you see the condition of the coil itself? If it is blocked this could be a cause for the frozen coils. Also, check the condition of the blades on the indoor fan. Dirt and dust accumulation on the blades reduces airflow.
Jul 14, 2014 | Ruud Handler Air Conditioner
Cannot find a filter location for RCBA 4882GG21.
it is either in the bottom of the indoor unit itself, in the door below the inside unit (if equipped), or in the grill on the wall or ceiling
Sep 30, 2012 | Ruud Matching Split Air Conditioner
I have a Ruud Split unit and the only number I can find on it is s9201a and I'm trying to find an air filter replacement. Can you help me. Thanks
the air filter will be in the wall of your house around the thermostat or in the indoor unit at the very bottom of it
Sep 24, 2010 | Ruud Central System Air Conditioner
I do have the Ruud split unit. My drain line was clogged and when I cut the line at the unit alot of water ran out. Could that of caused it to stop working. The fan will come on but I get no response...
Check for some type of float switch in the condensate pan. It will shut down the unit to prevent more condensate but I am not sure if it would still allow the indoor fan to run.
Sep 21, 2010 | Ruud UBHC Air Conditioner
I have a 4 ton Ruud HVAC system that is two years old. It is a 13 SEER unit. It is tilted slightly to the front of the evaporator to aid in draining the condensate. Two days ago, my daughter came home...
If the condensate drain is clogged, water will stay in the condensate pan located below the evaporator.
As the water builds it most certinly will be picked up by the blower and travel through the duct work.
Jul 03, 2010 | Ruud UBHC Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Water dripping (almost running) out of the left corner of air handling unit. Help???
You're correct in checking the drain pipe, because it's become blocked. The only trouble is, you're trying to clear the wrong end. The condensate water is spilling out of the air handler because that's where the pipe has a clog. These pipes usually have un-glued joints next to the air handler, for times such as this. If you can't pull them apart, you may have to cut the pipes and reconnect tham with fittings from the hardware store. (which is a normal procedure.) I usually use a wet/dry shop vac when repairing this problem, sucking out the clog & the water, then blowing out the line to where it drains outside. I've also used the clothes hanger technique to drag crud out of the air handler fitting. Hope this is helpful. ;)
Aug 10, 2007 | Ruud UAKA030 Air Conditioner
Ruud UAKA037 Air Conditioner Logo
460 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
