Question about Canon Office Equipment & Supplies
Canon ImageRunner C2058: Repeated noise in image. Drum issue?
Canon ImageRunner C2058: - It prints out repeated spots on the paper. Each print has this repeated mark about 1/4 inche diameter. I cleaned all possible areas but the result is the same. Is it time to change the drum?
Please help.
Thanks.
  • yeseri Jun 22, 2009
    The color of the spot is either black or grey. If fuser roller needs to be replaced, how much does it cost? Can you order for me if price is right?
    Problem Solver:
  • 7 Answers
The upper fuser roller is probably worn out. If the spot is of a particular color, then it may relate to that drum unit.
Posted on Jun 21, 2009
How do i stop my savin 2020 from printing a yellow streak on my color copies?
Sounds to me like either a faulty yellow toner cartridge (try replacing it) if the drum is integral with the toner this should clear it. Otherwise you may need to replace the yellow image drum.
Jun 09, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Canon Imagerunner 3025 B&W is printing what looks remants of an old ink each time we print out something? Like the rollers need to be cleaned? Any advice on how to solve ourselves?
There are 2 possible things that could be at fault here. One being the image is'nt fusing to the paper due to faulty operation of the fuser. If any of the toner/image on the paper is easily wiped off the paper then this is more than likely the issue. The second possible issue is that you have a bad drum unit, there is an internal cleaning blade that is used to scrape the excess toner from the last image off before creating another copy. On this particular machine the drum only comes as a unit and would need to be replaced. More than likely you need a new drum unit. P/N- 9630A003AA
Mar 09, 2012 | Canon ImageRunner 3025 Black and White...
I have canon copier ir c2100,i cant print becouse when ever i try printing it displays as out of paper but there is a lot of paper too what do i do
Try to put paper into the manual feed tray and let it print. I would check to see what you default tray is set to... It may be to the manual feed tray and make sure you have the correct paper size for your paper trays
May 16, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
I have a canon 4570 imagerunner,the problem i am facing is when i am printing a copy 2(sometimes 3) horizontal lines appears on the print.please sugest. Thank You
If the lines repeat in a regular fashion, with a consistent distance from each other, you need to replace the imaging drum. I would take a print out with the horizontal lines on it, then fold the paper up until two of the lines overlap each other; this will tell you the general diameter of the drum and give you an idea of what to look for inside the machine.
-David.
Nov 03, 2010 | Canon imageRUNNER 4570 Copier
Kids removed a jam, now all prints/copies are ghosted/smear
Sounds like they touched the photosensitive drum. It needs to be cleaned with a cotton cloth. The drum is a lime-color cylinder and it is very fragile. Avoid touching with any object other than the cloth it or scratching it.
Good luck.
Sep 29, 2009 | Canon MF3110 All-In-One Laser Printer
Canon imageRUNNER C2058 Color Copier/Printer service manual have error e240-0000
E240 Error in communication of controller
0000 Error in communication data Check connector, check connection of sub PCB in the
controller box, check / replace DC controller PCB /
main controller PCB
0001 There is no response when 3 sec passed since the main controller had sent the pickup
request to DC controller during printing.
0002 There is no response when 4 sec passed since the main controller had sent the request
for image output to DC controller during printing.
0003 The engine is activated when jam occurs.
Jul 09, 2009 | Canon C2058 Color Copier
HP Laserjet prints everything multiple times
Is it the same image being repeated ?
If so then it is the drum not the developer unit.
There is a device for discharging the image once it has been transfered to the paper from the drum.
If that is broken then the image is not cleaned off and will repeat.
The other thing to look at is your setup to make sure it is set at A4 and it is being told to print one copy per sheet
Jun 23, 2009 | Office Equipment & Supplies
Canon Copier MF 6530 stopped printing after a paper jam, everthing else works fine no error code just won't print. I have remove the cartridge shook it and still nothing. Do you have any suggestions?...
I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
Apr 04, 2009 | Canon imageRUNNER 5570 Copier
Ir 3300
Set print settings to print as image. Also make sure to spool printing.
Sep 19, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
79 people viewed this question
old marine
old marine
