Question about Whirlpool Refrigerators
Ice built up in the freezer compartment
My Refrigerator - Whirpool ED22RFXFW - has the optional automatic ice maker which is working fine. I found ice built up around the ice bin. I cleaned it and removed the ice bin.
The following day when I wanted to replace the ice bin back, I found ice built up on the interior side of the back wall surrounding the mechanism that engaged the auger of the ice bin. I noticed also ice built up on the upper part of interior side of the freezer door.
Please help me to find out what's the problem? What part(s) need to be replaced? Where to buy the part(s)?
Thank you,
Iwan
  • gwanrisman Jun 21, 2009
    Hi Sea,
    Thank you very much. I'll try it and keep you psoted
  • gwanrisman Jun 26, 2009
    Hi Sea,
    I called my Home Warranty Insurance company and they sent an appliances repaired contractor. The contractor's finding was air entering freezer compartment thru the ice dispenser because the dispenser had been broken. It would costs me $225.00 (Mat. & Lab) to replace the ice dispenser (Note this repair is not covered by the Home Warranty). Is it a reasonable price?
  • Whirlpool Master
  • 4,655 Answers
We have a possible defrost problem or the seal around your doors are pulling moist air air inside. I believe now would be a good time to unplug the refrigerator and check the coils and defrost system. Inside the fresh food compartment you have a defrost timer that I want you to turn clockwise slowly until the compressor stops. Leave it there for about 25 minutes until refrigerator either restarts or don't if it does not then turn it a little more until it starts. The part number for the timer is 482493 Also below is a picture and #6 is the defrost timer. It should be reachable through a small hole in the bottom of the control panel. If everythig is well there we will check the defrost heater and defrost thermostat. After you check these things let me know the results. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 21, 2009
  • 2 more comments
  • John Tripp
    John Tripp Jun 21, 2009
    You are welcome, I concentrated on defrost system but the door seals may be the problem. But this way you can check everything..Sea Breeze
  • John Tripp
    John Tripp Jun 26, 2009
    Considering the cost of someone coming out and finding the problem and replacing your ice maker I would consider the charges fair. I only wish I was able to help you. The replacement for your model is part number 4317943 found through my website.
  • John Tripp
    And Again Reading It was your dispenser. Sorry.
  • John Tripp
    Repair to the dispenser is complex and not for the average homeowner to attempt to to repair.
Where is the control for the freezer compartment
On the inner side of the freezer compartment.Its for cool,and winter mode,fast cooling mode.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
Not making ice but water dispensing ok whirpool ed5lhaxwboo thanks for any help
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker is not working on Whirpool model GD5NHAXMB00
Hi, Make sure the temp in the freezer is 0 to 5above zero. You might have another problem causing the icemaker to act up.
IfI can help further, please let me know.
Vic
May 11, 2009 | Whirlpool GS5SHAXN Side by Side...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
May 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
143 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
